Full range audio with Real Sound - incredibly spacious with enhanced excellent frequency performance, perfectly design for the real sound, which equipped with latest ripple design and smart handle.
Rubber Smart Handle can be propped up and forming prefect angle to reduce the surface of contact in between the speaker, which delivered more sound within the environments than most speakers.
With larger sound driver, delivered the extendable and detailed sound further away than most speakers.
Best audio performance
Full range audio with Real Sound - incredibly spacious with enhanced excellent frequency performance, perfectly design for the real sound, which equipped with latest ripple design and smart handle. -
Prefect angle for indoor or outdoor music experience
Rubber Smart Handle can be propped up and forming prefect angle to reduce the surface of contact in between the speaker, which delivered more sound within the environments than most speakers. -
Groovi Ripple with larger sound driver
With larger sound driver, delivered the extendable and detailed sound further away than most speakers. -
Pocket size with smart handle
Weighing only 175 grams, portable and lightweight enough with a smart handle that doubles as a stand to be propped up, grasping on a surface tightly or even making it attachable to most of the gear. See it now.
- TP-Link Groovi Ripple - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Frequency Response
- 120 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 9.4 cm x 3.7 cm x 10.3 cm
- 175 g
- Product Type
- Design Features
- Built-in carrying handle
Speaker System
- Speaker Type
- Active
- 120 - 20000 Hz
- Signal-To-Noise Ratio
- 65 dB
- Amplifier
- Integrated
- Bluetooth 4.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 20 m
- Controls
- Power on/off, volume, activate Bluetooth
Speaker System Details
- Driver Details
- Speaker: full-range driver
- Connector Type
- Audio line-in (mini-phone 3.5mm)
- Included Accessories
- USB charge cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 750 mAh
- Run Time (Up To)
- 4 hour(s)
- Recharge Time
- 2 hours
- 9.4 cm
- 3.7 cm
- 10.3 cm
- 175 g
