TP LINK Groovi Ripple Bluetooth Music Speaker
Quicklinx: BXP6WS00 Mfr#: Groovi Ripple
Full range audio with Real Sound - incredibly spacious with enhanced excellent frequency performance, perfectly design for the real sound, which equipped with latest ripple design and smart handle.
Rubber Smart Handle can be propped up and forming prefect angle to reduce the surface of contact in between the speaker, which delivered more sound within the environments than most speakers.
With larger sound driver, delivered the extendable and detailed sound further away than most speakers.
  • Best audio performance
  • Prefect angle for indoor or outdoor music experience
  • Groovi Ripple with larger sound driver
  • Pocket size with smart handle
    Weighing only 175 grams, portable and lightweight enough with a smart handle that doubles as a stand to be propped up, grasping on a surface tightly or even making it attachable to most of the gear. See it now.
TP-Link Groovi Ripple - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Frequency Response
120 - 20000 Hz
Amplifier
Integrated
Bluetooth
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
9.4 cm x 3.7 cm x 10.3 cm
175 g
Design Features
Built-in carrying handle
Speaker System
Speaker Type
Active
Frequency Response
120 - 20000 Hz
Signal-To-Noise Ratio
65 dB
Amplifier
Integrated
Bluetooth 4.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Transmission Range
20 m
Controls
Power on/off, volume, activate Bluetooth
Speaker System Details
Driver Details
Speaker: full-range driver
Connector Type
Audio line-in (mini-phone 3.5mm)
USB charge cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
750 mAh
Run Time (Up To)
4 hour(s)
Recharge Time
2 hours
9.4 cm
3.7 cm
10.3 cm
175 g
