TP LINK Deco X50 Whole Home WiFi System - 3 - Pack
Quicklinx: H3X3WS00 Mfr#: Deco X50(3-pack)
  • IEEE 802.11n
3 In Stock
£181.66 ex VAT
£217.99 inc VAT
Standard delivery Delivered within 3-5 working days
AX3000 Dual Band WiFi - Super-fast WiFi 6 with speeds up to 3.0 Gbps
4 Streams, Less Lag - 2×2/HE160 2402 Mbps + 2×2 574 Mbps
Gigabit Wired Speed - 3× Gigabit ports provide sufficient connectivity
Boosted Seamless Coverage - Seamless mesh WiFi coverage up to 6,500 ft2 (3-pack)
AI-Driven Mesh - Intelligently learns the network environment to provide ideal WiFi unique to your home
TP-Link HomeShield - Provides comprehensive network protection, robust parental controls, and real-time IoT protection
Setup Made Easier Than Ever - The Deco app walks you through the setup step-by-step
Ultra-Fast WiFi 6 Mesh
Armed with WiFi 6 technology, Deco whole home mesh WiFi is designed to deliver a huge boost in coverage, speed, and total capacity. Get on the latest mesh WiFi to enjoy the future network that loads faster and connects more
Whole-Home Coverage: WiFi Dead Zone Killer
With clearer and stronger signals enhanced by BSS Color and Beamforming, Deco X50 boosts broader whole home WiFi coverage with great performance. Wireless connections and optional Ethernet backhaul work together to link Deco units, providing even faster network speeds and truly seamless coverage. Want more coverage? Simply add another Deco
AI-Driven Mesh: Always Learning, Constantly Optimizing
Armed with AI-Driven Mesh, Deco X50 delivers smart WiFi that follows you wherever you are, without interruption. It automatically learns your network environment, client quality, and user behaviors. Sophisticated algorithms account for various factors so that Deco X50 provides ideal mesh WiFi, unique to your home. Walk through your home and enjoy seamless streaming at the fastest possible speeds
Seamless Roaming with One WiFi Name
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless WiFi experience
Quick Setup with the Deco App
Unbox Deco, install the app and then simply follow the on-screen directions. Deco app will take care of the rest, getting your network up and running in minutes.
More than a Router, Functional and Beautiful
The pure white design, simple but all-embracing, evokes a wintery mood or a bright summer day. Deco X50 with a delicate body case makes it perfect to blend into various home decorations.
  • Multiple installation options
    Deco X50-PoE has flexible installation to meet various demand scenarios. Place it on a tabletop or install it on a ceiling or wall.
  • Ideal for non-stop entertainments
    Armed with Wi-Fi 6 technology, Deco whole home mesh Wi-Fi is designed to deliver a huge boost in coverage, speed, and total capacity. Get on the mesh Wi-Fi to enjoy the future network that loads faster and connects more.
  • Powerful AX3000 dual-band Wi-Fi speed
    The 1024-QAM boosts speeds up to 3.0 Gbps - ideal for bandwidth-intensive tasks like cloud gaming and 8K video. Families will enjoy immersive live-streaming with flawless video and clear audio without buffering.
  • Multi-Gig 2.5 Gbps PoE port
    Armed with a 2.5 Gigabit Ethernet port, Deco X50-PoE delivers exceptional multi-Gigabit performance to support the insatiable demand for better and faster Wi-Fi. Breakthrough the 1G bottleneck and drive your devices to peak performance. Or using 2.5 GbE port to enjoy blazing-fast wired connections.
  • Power over Ethernet for simplified network deployment
    Deco X50-PoE is designed to use a single Ethernet cable for both data and power transmission. It also supports DC power supply for flexible installations.
  • Cover every corner of your home
    Deco units work together as a powerful mesh network to boost broader coverage for connections in every corner.
  • Engineered for more devices
    Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance.
  • Intelligent networking for a smarter home
    Deco uses its custom algorithms to automate the connections on your network, ensuring the strongest possible signals at all times.
  • Seamless roaming with one Wi-Fi name
    TP-Link mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
  • Compact design, easy to mount
    Exceptional performance with compact design ensures simple Wi-Fi installation while saving space. The elegant appearance makes Deco X50-PoE with a delicate body case makes it perfect to blend into various home decorations.
TP-Link Deco X50 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
Wi-Fi System Coverage
Up to 6,500 sq.ft
WAN Ports Qty
3
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Connected devices: 150
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6
Routing Protocol
Static IP routing
Intelligent Assistant
Alexa - indirect
Remote Management Protocol
DHCP, IPv4, IPv6
Content filtering, manageable, IPv6 support, IPS, parental control, Access Point operational mode, firmware upgradable, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, MU-MIMO technology, anti-virus protection, beamforming technology, router mode, guest access, seamless roaming, black list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6
11 cm x 11 cm x 11.4 cm
1.71 kg
Android, Apple iOS
3-year warranty
Wi-Fi system - mesh - 3-port switch (integrated)
3 routers
Up to 6,500 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Static IP routing
DHCP, IPv4, IPv6
Encryption Algorithm
WPA, WPA2-PSK, WPA3
Wi-Fi Rating
AX3000
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS, RCM
1 GHz
Line Properties
Line Coding Format
1024 QAM, OFDMA
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Alexa
Voice Controlled
Indirect
WAN / LAN: 3 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
Installed Qty
3
1 x network cable
OS Provided
No operating system
Android, Apple iOS
11 cm
11 cm
11.4 cm
1.71 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H3X3 051380
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £141.30
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Wi-Fi system
Connectivity: Wireless
Connectivity: Wired
Speed: 2402Mbps
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: IEEE 802.11ac
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11b
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ax (Wi-Fi 6)
Brand: TP LINK
Stock Status: Used Stock
