TP LINK Deco M4 Whole Home WiFi System - 2 Pack
Quicklinx: H3X5WS00 Mfr#: Deco M4(2-pack)
Type: Wi-Fi system
Connectivity: Wired, Wireless
Speed: 867Mbps
Protocol: Fast Ethernet, IEEE 802.11a, Ethernet, Gigabit Ethernet + 4 more
Compatibility: Apple iOS, Android
  • IEEE 802.11n
£73.33 ex VAT
£87.99 inc VAT
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage - eliminate weak signal areas once and for all! With advanced Deco Mesh Technology, units work together to form a unified network with a single network name. Devices automatically switch between Decos as you move through your home for the fastest possible speeds.
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that's not enough, simply add more Decos to the network anytime to increase coverage.
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage — eliminate weak signal areas once and for all
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that’s not enough, simply add more Decos to the network anytime to increase coverage.
Deco M4 provides fast and stable connections with speeds of up to 1167 Mbps and works with major internet service provider (ISP) and modem.
Deco can handle traffic from even the busiest of networks, providing lag-free connections for up to 100 devices
Parental Controls limits online time and block inappropriate websites according to unique profiles created for each family member.
Setup is easier than ever with the Deco app there to walk you through every step.
2-in-1 Router and Access Point Modes
Flexible and multifunctional, the Deco M4 includes a variety of features allowing it to serve as a router or access point. Just choose the mode for your actual network demands and experience the maximum wireless flexibility.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance
Seamless Roaming with One Wi-Fi Name
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
Experience Wi-Fi Like Never Before
Deco M4 uses TP-Link Mesh technology to cover your entire home in powerful Wi-Fi. Multiple units seamlessly work together to create a home network like nothing you’ve ever experienced.
  • Wi-Fi dead-zone killer
    Deco M4 is the simplest way to guarantee a strong Wi-Fi signal in every corner of your home up to 2,800 square feet (2-pack). Wireless connections and optional Ethernet backhaul work together to link Deco units, providing even faster network speeds and truly seamless coverageWant more coverage? Simply add another Deco.
  • Seamless roaming with one Wi-Fi name
  • No more buffering
    Network speeds three times faster than previous generation routers, thanks to 802.11ac wireless technology, make Deco capable of providing a lag-free connection to up to 100 devices.
  • Multiple 3-in-1 router, access point and range extender modes
    Flexible and multifunctional, the Deco M4 includes a variety of features allowing it to serve as a router, access point or range extender. Just choose the mode for your actual network demands and experience the maximum wireless flexibility.
  • Easy management
    Manage your Wi-Fi at home or away in the Deco app, including seeing the connected devices, prioritizing your devices, setting up a guest network and more.
  • Robust parental controls
    Simple, intuitive parental controls make it easy to keep your children safe while they're online. Easily create a profile for each family member and set custom time limits and online time allowances.
TP-Link DECO M4 - Wi-Fi system - Wi-Fi 5 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
Wi-Fi System Coverage
Up to 2,800 sq.ft
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
IPv6 support, parental control, Access Point operational mode, firmware upgradable, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, DHCP client, MU-MIMO technology, beamforming technology, router mode
9.07 cm x 9.07 cm x 19 cm
730 g
Android 4.3 or later, Apple iOS 9 or later
3-year warranty
Wi-Fi system - mesh
2 routers
Up to 2,800 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, VCCI, BSMI, IC, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA
Qualcomm
RAM
128 MB
Flash Memory
16 MB
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
Installed Qty
2
1 x network cable
9.07 cm
9.07 cm
19 cm
730 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Speed: 867Mbps
Protocol: IEEE 802.11a
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Android
Antennas: 2
Brand: TP LINK
