24W 2-Port USB Car Charger
- Exclusive Auto Detect & Smart Charging Technology
- 1.65X Fast Charging
- Intelligent Circuit Design
- Universal Compatibility
- Considerate Design
Speed
CP220 is equipped with TP-LINK Smart Charging technology and incorporates high performance dual 2.4A USB outputs. TP-LINK Smart Charging technology intelligently identifies the connected devices and the 2.4A USB ports in CP220 allow you to charge devices with large battery like tablets, or gadgets with tiny battery like smart wearable devices at full speed on the road.
30 mins drive adds 9 additional using hours
As measured by the charging capacity in 30 mins on iPhone 6s Plus, it charges up to 38% within the drive in order to provide 9 additional hours 3G talk time for further use.
1.65X Fast Charging compared with original charger
Charge 65% faster, save up to 40% charging time. Fully charging iPhone 6s Plus takes 150 mins with CP220 while it takes 250 mins with an original Apple charger.
Compatible with smart devices running iOS, Android, Windows and most other USB-charged devices, such as Satellite Navigation and Dashcams. CP220 fully supports and is applicable to most of the current car models.
A unique crown design
The crown design ensures users insert CP220 in the right position and connect devices in the most convenient way.
Built in soft internal LED power indicator
A dimmed LED indicator helps visualize the connection status and does not distract you while driving.
Fast without limitation
CP220 is equipped with TP-LINK Smart Charging technology and incorporates the high performance dual 2.4 A USB outputs. TP-LINK Smart Charging technology intelligently identifies the connected devices to ensure no matter a short distance drive or a long journey ride, the 2.4 A USB ports in CP220 allow you to charge either devices with large battery like tablets, or gadgets with tiny battery like smart wearable devices at full speed on the road. -
1.65x fast charging compared with original charger
Charge 65% faster, save up to 40% charging time. Fully charging iPhone 6s Plus takes 150 mins with CP220 while it takes 250 mins with an original Apple charger. -
Safety as your first priority
The safety issue in a car is seriously taken, either should be in a car charger. CP220 has a sophisticated circuit design with Multiple protections against over-heat, over-current, over-charging and short circuit. -
A fine piece of work through strict quality controls
Premium manufacturing through numbers of strict quality controls ensures every details in CP220 are prudently considered and making it as a flawless product. CP220 is fabricated by high quality polycarbonate and Acrylonitrile Butadiene Styrene with superior metallic findings not only make it sturdy and durable but also allow you to power up in style. -
Universal compatibility
Compatible with smart devices running iOS, Android, Windows and most other USB-charged devices, such as GPS Navigator and Event Data Recorder. CP220 fully supports and is applicable to most of the current car models. -
The crown design ensures users insert CP220 in the right position and connect devices in the most convenient way. -
- TP-Link CP220 car power adapter - USB - 24 Watt
- Product Type
- Car power adapter
- 2.7 cm x 2.8 cm x 7.7 cm
- Output Connector Type
- Total 2: USB
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.4 A
- Power Provided
- 24 Watt
- Product Type
- Car power adapter
- 2.7 cm
- 2.8 cm
- 7.7 cm
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Power Provided
- 24 Watt
- 2.4 A
- Short circuit protection, overcharging protection, overheat protection, over-current protection, Smart Charge Technology
- FCC, RoHS, EAC
