TP LINK BE9300 Tri-Band Wi-Fi 7 Router
Quicklinx: J1R9WS00 Mfr#: Archer BE550
  • IEEE 802.11n
19 In Stock
£162.49 ex VAT
£194.98 inc VAT
Wi-Fi 7 Routers
With powerful Wi-Fi 7 performance, lightning-fast wired connections, and brand-new design
Blazing-Fast 9214 Mbps Tri-Band wireless Router
Enables your devices to run at full speed; Enjoy fluent 4K/8K streaming, immersive AR/VR gaming, and blazing-fast downloads
Multi-Link Operation (MLO)
Increases throughput, reduces latency, and improves reliability for emerging applications
5× 2.5G Ports
1× 2.5 Gbps WAN port and 4× 2.5 Gbps LAN ports break through the 1G bottleneck, driving your devices to peak performance
Maximized Coverage
Proprietary Wi-Fi optimization and optimally positioned antennas along with Beamforming deliver more capacity, stronger and more reliable connections, and less interference
EasyMesh-Compatible
Works with EasyMesh routers and range extenders to form seamless whole home Mesh Wi-Fi, preventing drops and lag when moving between signals
Easy Setup and Use
Network management has never been easier with the Tether app
TP-Link HomeShield
Enhanced security defends against the latest cyber threats
Great Compatibility
Supports all Wi-Fi generations and devices**and all internet providers
  • Robust connectivity options
    The Archer BE550 V2 provides multiple ports including four for WAN and LAN connections alongside a USB 3.0 port, enabling versatile connectivity for various devices and applications.
  • Advanced security features
    This wireless router includes several encryption protocols such as WPA3 and advanced parental control options to ensure a secure online environment for all connected devices.
  • Wireless performance
    With a maximum data transfer rate of 9214 Mbps and support for Wi-Fi standards, this device is designed to deliver high-speed Internet for streaming, gaming, and more.
  • Smart home compatible
    Compatible with popular voice assistants like Google Assistant and Alexa, the Archer BE550 V2 enhances home automation capabilities, allowing users to manage their network conveniently.
  • Optimized for high-definition content
    The router is capable of supporting 4K/8K UHD video streaming, making it perfect for households that enjoy high-definition media without interruptions.
TP-Link Archer BE550 V2 - wireless router - Wi-Fi 7 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6E), IEEE 802.11be (Wi-Fi 7)
Frequency Band
2.4 GHz / 5 GHz / 6 GHz
Data Transfer Rate
9214 Mbps
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2880 Mbps , Maximum data rate (6 GHz): 5760 Mbps , Channel bandwidth: up to 320 MHz , Aggregate data rate: 5 Gbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6, WireGuard, OpenVPN
Routing Protocol
IGMP, static IP routing
Intelligent Assistant
Google Assistant, Alexa - indirect
Remote Management Protocol
DHCP
NAT support, IGMP snooping, parental control, Access Point operational mode, DDos attack prevention, ACL support, QoS, Samba support, FTP server, port forwarding, reset button, port triggering, SPIF, IP-MAC binding, tagged VLAN, VPN Server, IGMP proxy, 802.1x authentication, router mode, LED on/off button, seamless roaming, Airtime Fairness, Smart Roaming, DMZ support, DynDNS, bridge mode, OpenVPN server, IPTV support, WPS button, EasyMesh, 4K/8K UHD video streaming, Guest Network, TP-Link HomeShield, SIP ALG, Wi-Fi on/off button, Hassle Free, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, remote firmware upgrade, anti-jamming, PPTP VPN server, MLO, MRU, L2TP VPN server
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7
7.6 cm x 23.17 cm x 20.3 cm
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
9214 Mbps
Performance
Routing Protocol
DHCP
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Wi-Fi Rating
BE9300
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7, FCC, RoHS
Line Properties
Line Coding Format
4096 QAM, OFDMA
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
WAN: 1 x 2.5GBase-T - RJ-45 , LAN: 4 x 2.5GBase-T - RJ-45 , USB 3.0: 1 x
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
1 x network cable
7.6 cm
23.17 cm
20.3 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Standards: IEEE 802.11be (Wi-Fi 7)
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ax (Wi-Fi 6E)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Speed: 9214Mbps
Brand: TP LINK
