TP LINK BE3600 Dual-Band Wi-Fi 7 Router
Quicklinx: J1R7WS00 Mfr#: Archer BE230
  • IEEE 802.11n
Hurry, only 2 left in stock!
£70.83 ex VAT
£84.99 inc VAT
3.6 Gbps Dual-Band WiFi 7
Powered by Wi-Fi 7 technology, Archer BE3600 delivers an incredible wireless rate of up to 3.6 Gbps, enabling your devices to run at full speed; Enjoy fluent 4K/8K streaming, immersive AR/VR gaming, and blazing-fast downloads
2x 2.5G Ports
1x 2.5 Gbps WAN port, 1x 2.5 Gbps LAN port and 3x 1 Gbps LAN ports offer high-speed data transmissions; Easily share files between connected devices by plugging into an external drive; You can even make it your personal cloud storage and access it from outside securely
Maximized Coverage
4x external antennas along with Beamforming deliver more capacity, stronger and more reliable connections, and less interference
EasyMesh-Compatible
Works with EasyMesh routers and range extenders to form seamless whole home Mesh WiFi, preventing drops and lag when moving between signals
Easy Setup and Use
Network management has never been easier with the Tether app; Supports all Wi-Fi generations and devices and all internet providers
  • Enhanced connectivity
    With a combination of Ethernet 2.5GBase-T and Gigabit Ethernet interfaces, this router ensures high-speed wired connections, complemented by Wi-Fi 6 technology for seamless wireless connectivity.
  • Comprehensive security
    Equipped with WPA3 encryption and a suite of security features including Access Control List (ACL) support, Intrusion Prevention System (IPS), and TP-Link HomeShield, this router provides robust protection against cyber threats.
  • Optimized performance
    Features like 2x2 MU-MIMO technology, beamforming technology, and a data transfer rate of up to 3.6 Gbps enhance the efficiency and reliability of your network, ensuring smooth streaming and gaming experiences.
  • Smart home ready
    Compatibility with intelligent assistants like Alexa and Google Assistant, along with IoT-ready features, makes this router an ideal choice for a smart home ecosystem.
  • User-friendly features
    Parental controls, guest network capabilities, and easy setup options provide a user-friendly experience, while the USB 3.0 port adds convenience for file sharing and storage.
TP-Link Archer BE230 V1 - wireless router - Wi-Fi 7 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6), IEEE 802.11be (Wi-Fi 7)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.6 Gbps
Performance
Maximum data rate (2.4 GHz): 688 Mbps , Maximum data rate (5 GHz): 2882 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, FTP, DHCP, DDNS, IPv4, IPv6, WireGuard, OpenVPN
Routing Protocol
IGMP, static IP routing
Intelligent Assistant
Google Assistant, Alexa - indirect
IGMP snooping, DFS support, IPS, parental control, Access Point operational mode, DDos attack prevention, ACL support, QoS, DHCP server, Samba support, port forwarding, reset button, port triggering, SPIF, dynamic IP mode, DHCP client, tagged VLAN, VPN Server, IGMP proxy, 802.1x authentication, beamforming technology, VPN client, router mode, IPMB, LED on/off button, Airtime Fairness, 2x2 MU-MIMO technology, Smart Roaming, DMZ support, DynDNS, bridge mode, IPTV support, WPS button, EasyMesh, auto firmware update, Guest Network, TP-Link HomeShield, Address Reservation, Wi-Fi on/off button, Real-Time IoT Protection, Malicious Site Blocker, Home Network Scanner, MLO, MRU
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7
27.27 cm x 14.7 cm x 4.17 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.6 Gbps
Performance
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Wi-Fi Rating
BE3600
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, IEEE 802.11be, Wi-Fi CERTIFIED 7, FCC, RoHS
Line Properties
Line Coding Format
4096 QAM, OFDMA
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
WAN: 1 x 2.5GBase-T - RJ-45 , LAN: 1 x 2.5GBase-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 3.0: 1 x
Aerial
Aerial
External
Antenna Qty
6
External power adapter
1 x network cable
27.27 cm
14.7 cm
4.17 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11a
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11ax (Wi-Fi 6)
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ac
Standards: IEEE 802.11be (Wi-Fi 7)
Speed: 3.6Gbps
Brand: TP LINK
