TP LINK AX11000 Tri-Band Wi-Fi 6 Gaming Router
Quicklinx: FNLKWS00 Mfr#: Archer AX11000
Type: Wireless router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n + 6 more
Speed: 4804Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£299.17 ex VAT
£359.00 inc VAT
Armed with Wi-Fi 6, Archer AX11000 becomes the speed machine that offers astonishing Wi-Fi speeds with an extended range.
  • More connected devices shall bring more fun rather than dragging the performance
    OFDMA technology is introduced to improve average throughput and cut the latency. Take advantage of incredibly low latency to demolish your enemies, with your team crew together.
  • Crush the lag
    Game accelerator automatically detects and optimizes gaming streams, to ensure your gaming stays immersive, and keep your network as fast as your reaction speed.
  • Know your network
    Game statistics shows the real-time latency, game duration and system utilization at a glance in a refreshed dashboard with fine-tuned UI elements, puts total control at your fingertips.
  • Game in the fast lane
    DFS expands available channel automatically, get on the more vacant lane and boost the game.
TP-Link Archer AX11000 - wireless router - Wi-Fi 6 - desktop
Wireless router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
4804 Mbps
Performance
Maximum data rate (2.4 GHz): 1148 Mbps , Maximum data rate (5 GHz): 4804 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Firewall protection, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
28.8 cm x 28.8 cm x 18.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
4804 Mbps
Performance
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Status Indicators
Port status, power, link/activity
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 2.5GBase-T - RJ-45 , USB 3.0: 1 x , USB 3.0: 1 x 24 pin USB-C
Aerial
Aerial
External
Antenna Qty
8
External power adapter
1 x network cable
28.8 cm
28.8 cm
18.4 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Fast Ethernet
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ac
Standards: IEEE 802.11ax (Wi-Fi 6)
Speed: 4804Mbps
Brand: TP LINK
