TP LINK AV600 Powerline Wi-Fi Extender 2 ports
Quicklinx: CMBDWS00 Mfr#: TL-WPA4220 V1.20
Type: Bridge
Speed: 600Mbps
Connectivity: Wired, Wireless
  • IEEE 802.11n
£29.22 ex VAT
£35.06 inc VAT
TP-LINK's TL-WPA4220 extends your Internet connection to every room of the house through your home's existing electrical circuitry. The TL-WPA4220 features a Wi-Fi Clone Button enabling Super Range Extension, which means it can automatically copy the SSID and Password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
  • Reverse your knowledge of powerline
    What jumps into your mind when it comes to electricity? TP-LINK's powerline adapters make it more than just a means of providing power to a home's myriad devices, but also transferring means by which to transfer data, which means you're able to getting access to the Internet wherever there's a power outlet, without the need for renovations or extra wiring.
  • Great experience for multimedia entertainment
    With powerline speeds of up to 600 Mbps and high-performance data transmission, TL-PA6030KIT can transmit multiple HD video streams and even 3D movies to every room, making it a great choice for an easy-to-build multimedia entertainment network.
  • Multiple network applications
    Featuring three Gigabit Ethernet ports, TL-PA6030KIT allows you to connect several devices, such as game consoles, IPTVs or media receivers, at the same time just by plugging in network cables, avoiding the hassle of adding other networking devices for more access to the Internet.
TP-Link TL-WPA4220 AV600 WiFi Powerline Extender - V1.20 - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
600 Mbps
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV
9.4 cm x 5.4 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8
Europe
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
600 Mbps
Max Range Indoors
300 m
Encryption Algorithm
WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, FCC, RoHS
Status Indicators
Power, WLAN, LAN, powerline
Line Properties
Line Coding Format
OFDM
LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
6 Watt
1 x network cable - 2 m
Europe
Software Included
Drivers & Utilities
9.4 cm
5.4 cm
4 cm
10 - 90% (non-condensing)
Type: Bridge
Speed: 600Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: TP LINK
Price Range Ex VAT: 0 - 50
