TP-LINK's TL-WPA4220 extends your Internet connection to every room of the house through your home's existing electrical circuitry. The TL-WPA4220 features a Wi-Fi Clone Button enabling Super Range Extension, which means it can automatically copy the SSID and Password of your router. In this way, TL-WPA4220 simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
Reverse your knowledge of powerline
What jumps into your mind when it comes to electricity? TP-LINK's powerline adapters make it more than just a means of providing power to a home's myriad devices, but also transferring means by which to transfer data, which means you're able to getting access to the Internet wherever there's a power outlet, without the need for renovations or extra wiring. -
Great experience for multimedia entertainment
With powerline speeds of up to 600 Mbps and high-performance data transmission, TL-PA6030KIT can transmit multiple HD video streams and even 3D movies to every room, making it a great choice for an easy-to-build multimedia entertainment network. -
Multiple network applications
Featuring three Gigabit Ethernet ports, TL-PA6030KIT allows you to connect several devices, such as game consoles, IPTVs or media receivers, at the same time just by plugging in network cables, avoiding the hassle of adding other networking devices for more access to the Internet.
- TP-Link TL-WPA4220 AV600 WiFi Powerline Extender - V1.20 - powerline adapter - Wi-Fi - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 600 Mbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV
- 9.4 cm x 5.4 cm x 4 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8
- Localisation
- Europe
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 600 Mbps
- Max Range Indoors
- 300 m
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, FCC, RoHS
- Status Indicators
- Power, WLAN, LAN, powerline
Line Properties
- Line Coding Format
- OFDM
- LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- 6 Watt
- Cables Included
- 1 x network cable - 2 m
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- OS Required
- 9.4 cm
- 5.4 cm
- 4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
