TP LINK AV600 Nano Powerline Adapter Starter Kit
Quicklinx: CMB8WS00 Mfr#: TL-PA4010KIT V1.20
Using advanced Home Plug AV technology, TL-PA4010KIT provides users with stable, high-speed data transfer rates of up to 600 Mbps on a line length of up to 300 meters. With speed of up to 600 Mbps, TL-PA4010KIT enables heavy-bandwidth applications like HD streaming, on-line gaming and large file downloading, turning your home into a robust and high-speed networking.
With its ultra-compact housing design, TL-PA4010KIT is much smaller than TP-LINK's legacy mini 600 Mbps powerline products. At just 28.5 mm thick, it nearly blends completely in front of any power outlet.
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
  • Up to 600 Mbps powerline speeds ideal for HD streaming
  • Miniature design
  • Pair button for easy network security
TP-Link Powerline AV600 Nano Adapter - Starter Kit - bridge - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
IEEE 802.3, IEEE 802.3u, HomePlug AV
6.5 cm x 5.2 cm x 2.85 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
United Kingdom, United States, Europe
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, Plug and Play, FCC, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
1 x HomePlug AV - power , LAN: 1 x 10Base-T/100Base-TX - RJ-45
4.6 Watt
Software Included
Drivers & Utilities
6.5 cm
5.2 cm
2.85 cm
10 - 90% (non-condensing)
