TP LINK AV500 Powerline AC Wi-Fi Kit
Quicklinx: BV3GWS00 Mfr#: TL-WPA4530KIT
  • IEEE 802.11n
Based on the Powerline technology, your network extension is never limited to the primary coverage of your router. Using your existing electrical wiring, this kit brings network to anywhere there is a power outlet. You can easily create a dual-band Wi-Fi network (simultaneous use of 2.4 GHz and 5 GHz bands) with more bandwidth and less interference, maximizing the performance of your Powerline network. A unified network allows you to stay connected, even when you're on the go. You can enjoy a single, seamless network throughout your entire home or office, without having to switch from one hotspot to another.
  • Extend dual-band Wi-Fi to any room
  • Dual-band Wi-Fi
  • Plug, pair and play
    Plug the TL-PA4020P in the wall and connect it to the router with an Ethernet cable, plug the TL-WPA4530 in any desired power outlet and press the "Pair" buttons on both adapters to create a secure network. There you go! Just enjoy the seamless, high-speed wired and wireless network
  • Easy network extension with the touch of a button
    Simply press your extender's Wi-Fi Clone button and your router's WPS button to automatically copy the network name and password from your primary router. This creates a unified network and eliminates the need for complex configuration.
  • Easily add additional extenders with Wi-Fi Auto-Sync
    If you ever decide to add more extenders to your Powerline network, the process will be just as simple as the initial setup. The Wi-Fi Auto-Sync function allows you to simply plug, pair and play! Your existing Wi-Fi settings will be synchronized to the new extender automatically. Any time you change the settings for one extender, all other extenders in the network will be updated as well.
  • Seamless Wi-Fi coverage
  • Turn any power outlet into 3 Ethernet ports
    With 3 Ethernet ports, the TL-WPA4530 provides up to three wired connections for your wired-only devices like PCs, game consoles, and smart TVs to your network. Just plug in and enjoy.
TP-Link TL-WPA4530 KIT AV500 Powerline ac Wi-Fi Kit - powerline adapter kit - 802.11a/b/g/n/ac - wall-pluggable
Powerline adapter kit
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
500 Mbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
128-bit encryption, VLAN support, Quality of Service (QoS), reset button, Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, IEEE 802.11ac
13.1 cm x 7.2 cm x 4.7 cm
Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
500 Mbps
Max Range Indoors
300 m
Routing Protocol
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA2-Enterprise, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, IEEE 802.11ac, FCC, RoHS
Status Indicators
Power, WLAN, LAN
Line Properties
Line Coding Format
OFDM
3 x 10Base-T/100Base-TX - RJ-45
Internal power supply
8 Watt
TP-Link AV500 Powerline Adapter (TL-PA4020P)
2 x network cable - 2 m
Software Included
Drivers & Utilities
13.1 cm
7.2 cm
4.7 cm
10 - 90% (non-condensing)
