TP LINK AV1300 Gigabit Powerline ac WiFi Kit
Quicklinx: F9DYWS00 Mfr#: TL-WPA8630 KIT V2
  • IEEE 802.11n
The TL-WPA8630 KIT expands your home's Wi-Fi coverage into areas where the wireless signal from the main router is weak or nonexistent. The range extender kit can build a unified network using your home's existing powerlines and allow you to enjoy Wi-Fi coverage in any area with a power outlet. The TL-WPA8630 utilizes 802.11ac Wi-Fi to deliver dual band connections with combined speeds of up to 1200Mbps, including 867Mbps on the 5GHz band and 300Mbps on the 2.4GHz band. The combination of impressive speed and convenient powerline networking allows you to provide fast, reliable connections throughout your entire home. This is perfect for 4K streaming and online gaming, on multiple devices at the same time.
Advanced HomePlug AV2 technology means the extender supports 2x2 MIMO with beamforming, so users benefit from ultra-fast data transfer speeds of up to 1200Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers. 2X2 MIMO is like adding extra lanes to a highway. It establishes multiple simultaneous connection for you to enjoy higher speeds and greater stability. 2X2 MIMO with Beamforming technology also offers the benefit of improved coverage throughout the home, particularly for previously hard to reach outlets.
  • Fast dual-band Wi-Fi for every need in every room
    450 Mbps (2.4 GHz) is ideal for browsing the web and video chatting, while 867 Mbps (5 GHz) is perfect for HD streaming and lag-free gaming.
  • 2x2 MIMO for more throughput over powerline
    2x2 MIMO technology is like adding an extra lane on a highway. It establishes multiple simultaneous connections so you can enjoy 2x faster, more stable powerline speeds.
  • Wi-Fi Auto-Sync for a unified, powerful network
    Powerline extenders simply copy your router's Wi-Fi settings and apply any changes across the secure powerline network with Wi-Fi Clone and Wi-Fi Move.
  • HomePlug AV2 standard compliant
    HomePlug AV2 provides users with stable, high-speed data transfer rates of up to 1300 Mbps on a line length of up to 300 meters.
  • Pair button
    Provides a connection with 128-bit AES encryption, at the touch of "Pair" button.
  • Parental controls
    Manage when and how connected devices can access the Internet.
  • Gigabit Ethernet ports
    Provide reliable high-speed wired connections for game consoles, smart TVs and NAS.
TP-Link TL-WPA8630 KIT V2 - bridge - Wi-Fi 5 - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP
128-bit encryption, manageable, parental control, WPA2 encryption, QoS, WPS, 2T2R MIMO technology, Wi-Fi Move technology, WPA encryption, AES encryption, PSK, Wi-Fi Clone button, Wi-Fi Auto-Sync
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac
14.06 cm x 6.8 cm x 4.5 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7, Windows 8 / 8.1 / 10
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Max Range Indoors
300 m
Routing Protocol
HTTP
Encryption Algorithm
WPA-PSK, 128-bit AES, WPA2-PSK, WEP
Authentication Method
Radio Service Set ID (SSID)
Wi-Fi Rating
AC1350
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac, Plug and Play, FCC Part 15 B, RoHS, CAN ICES-3 Class B, WEEE 2012/19/EU
Status Indicators
Power, WLAN, LAN, powerline
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
13.3 Watt
TP-Link TL-PA8010P
2 x network cable - 2 m
14.06 cm
6.8 cm
4.5 cm
10 - 90% (non-condensing)
