Product
TP LINK Auranet EAP330 Radio Access Point 802.11a/b/g/n/ac
Quicklinx: CM9ZWS00 Mfr#: EAP330
  • IEEE 802.11n
The combination of 802.11ac Wi-Fi and MIMO and TurboQAM technology allows EAP series devices to offer an unbeatable Wi-Fi experience. Broadcom enterprise-class chipsets offers amazing enterprise-grade performance, resulting in longer spans of stable operation and larger client capacities. The dedicated high-power amplifier, professional antenna, and well-designed RF shield ensure great wireless performance. Link aggregation combines two wired connections to double throughput and provide a redundant link for Internet access. Airtime Fairness improves total Wi-Fi throughput by limiting access time for low speed devices.
Band Steering pushes dual-band devices to the wider and faster 5GHz band, improving overall network performance, especially in high client density environments. Beamforming technology achieves superior Wi-Fi bandwidth utilization and increases Wi-Fi range by creating efficient, highly targeted Wi-Fi connections Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password.
  • Breakthrough Wi-Fi speeds ensure a true business-class experience
  • Amazing Wi-Fi performance for business environments
  • Airtime Fairness
  • Band Steering
  • Beamforming technology
  • Efficient guest authentication
  • Flexible Deployment
    The EAP's low profile design and easy mount chassis make it easy to install the device on any wall or ceiling surface and allow it to blend in with most interior decorating styles. EAP series APs support Power over Ethernet (PoE), making deployment effortless and flexible.
  • Applicable to multi-user environment
    With breakthrough 11AC speed, business-grade Wi-Fi performance, efficient captive portal function, low profile design and PoE support feature, the EAP 330 series are more capable of serving the high-density, demanding business environments, including schools, hotels, and enterprises.
TP-Link Omada EAP330 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wall mounting kit, ceiling mounting kit
Microsoft Windows Vista / XP / 7 / 8, Windows 10
Power Over Ethernet (PoE) Supported
PoE
22.05 cm x 19.35 cm x 3.65 cm
Radio access point
22.05 cm
19.35 cm
3.65 cm
External
Wireless
Data Transfer Rate
1900 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Load balancing, VLAN support, E-mail alert, MAC address filtering, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, Captive Portal, security lock slot (cable lock sold separately), Broadcom TurboQAM technology, Watch Dog Timer (WDT), beamforming technology, band steering, rate limit, Wireless Scheduler
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Omni-directional
2 x 1000Base-T (PoE) - RJ-45
UL 2043, FCC, RoHS
PoE
External power adapter
14 Watt
10 - 90% (non-condensing)
