TP LINK Archer VR600 V2 Wireless Router DSL modem 4-Port Switch
Quicklinx: D2FBWS00 Mfr#: ARCHER VR600 V2
  • IEEE 802.11n
30 in stock
£80.85 ex VAT
£97.02 inc VAT
The Archer VR600 unlocks the full potential of your Internet connection by providing combined dual band Wi-Fi speeds, eliminating lag and buffering from your online experience. Dedicated Wi-Fi networks support more devices and reduce wireless interference to create stable connections.
  • Superfast VDSL broadband
    The advanced VDSL2 technology allows the Archer VR600 to deliver impressive VDSL broadband speeds. The Archer VR600 serves as a DSL modem and wireless router, combining two devices in one. The integrated DSL port supports all standard DSL connections.
  • Versatile connectivity
    With multiple inputs, the Archer VR600 provides you with a variety of functions, when connecting to the Internet. As a backup, the EWAN port allows the Archer VR600 to accept connections from cable and fiber modems via Ethernet cable. Additionally, both of the two USB ports support 3G/4G dongle connections.
  • Superior range and stability
    High-performance external antennas help the Archer VR600 create an expansive home network. Advanced Beamforming technology automatically locates wireless devices and forms targeted, highly efficient wireless connections.
  • Blazing fast wired performance
    To help your wired devices achieve peak performance, the router's Gigabit Ethernet ports operate faster. Connecting an external drive to one of the USB 2.0 ports allows you to share files, photos, music, and video with any device on the network.
  • Impressive aesthetics
    The glossy body of the Archer VR600 makes it a stylish addition to the decor of any room in your home. The accents also provide an aura of elegance, making your router easy to display, whether it is simply placed on a table or mounted on the wall. For added convenience, you can easily disable the LED indicators to prevent distractions at night.
TP-Link Archer VR600 - v2 - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1600 Mbps
IPSec VPN tunnels: 10 , Permanent virtual circuits (PVC): 8
Network / Transport Protocol
TCP/IP, PPTP, IPSec, PPPoE, PPPoA, IPoA, IPoE, DHCP, DNS, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS, CLI, TR-069
Firewall protection, DMZ port, NAT support, VPN support, DoS attack prevention, ALG support, dynamic DNS server, manageable, print server, IPv6 support, Wireless Distribution System (WDS) support, parental control, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, IPv4 support, port triggering, DHCP relay, Traffic Control, IP-MAC binding, DNS relay, DHCP client, SYN Flooding, Ping of Death, SFTP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
21.6 cm x 16.4 cm x 3.68 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1600 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS, RCM
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.998.4, ITU G.993.5
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11 , Antenna: 3 x RP-SMA
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
ADSL splitter
1 x network cable , 1 x phone cable
21.6 cm
16.4 cm
3.68 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1600Mbps
Brand: TP LINK
Price Range Ex VAT: 50 - 100
