TP LINK ARCHER T4U AC1200 Wireless Dual Band USB Adapter
Quicklinx: 9BPBWS00 Mfr#: ARCHER T4U
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
TP-LINK's Archer T4U comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds. With 867Mbps wireless speeds over the crystal clear 5GHz band or 300Mbps over the 2.4GHz band, the Archer T4U is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
AC1200 Wireless Speed
The 5GHz 867Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4GHz 300Mbps Wi-Fi for normal use such as web surfing
USB 3.0 - Up to 10X faster than USB 2.0
Experience blazing speed data transfers of up to 4.8Gbps with USB 3.0 - the latest USB connectivity standard. USB 3.0 transfers data up to 10X faster than USB 2.0 and is also backward compatible with USB 2.0. This high-speed transfer rate combine with 802.11ac ideal for HD streaming, online gaming and large file downloads.
The Best of Both Bands
TP-LINK's Archer T4U is an AC1200 Wireless Dual Band USB Adapter giving users the ability to access crystal clear 5GHz connections or legacy 2.4GHz connections to upgrade their notebook or PC's wireless capabilities to operate with new 5GHz band wireless networks, while ensuring that they can still access legacy 2.4GHz band wireless networks.
Bundled USB Extension Cable
Archer T4U equipped with the 1m USB 3.0 extension cable, which extend the USB connection length, making it more convenient to plug the USB device in & out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
  • 802.11ac
    TP-LINK's Archer T4U comes with the Wi-Fi standard - 802.11ac, 3 times faster than Wireless N speeds. With 867 Mbps wireless speeds over the crystal clear 5 GHz band or 300 Mbps over the 2.4 GHz band, the Archer T4U is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
  • AC1200 wireless speed
    The 5 GHz 867 Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4 GHz 300 Mbps Wi-Fi for normal use such as web surfing
  • USB 3.0 - up to 10x faster than USB 2.0
    Experience blazing speed data transfers of up to 4.8 Gbps with USB 3.0 - the USB connectivity standard. USB 3.0 transfers data up to 10x faster than USB 2.0 and is also backward compatible with USB 2.0. This high-speed transfer rate combine with 802.11ac ideal for HD streaming, online gaming and large file downloads.
  • The best of both bands
    TP-LINK's Archer T4U is an AC1200 wireless dual-band USB adapter giving users the ability to access crystal clear 5 GHz connections or legacy 2.4 GHz connections to upgrade their notebook or PC's wireless capabilities to operate with 5 GHz band wireless networks, while ensuring that they can still access legacy 2.4 GHz band wireless networks.
TP-Link Archer T4U - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
9.22 cm x 2.9 cm x 1.46 cm
Wi-Fi 5
Data Transfer Rate
1.2 Gbps
Frequency Band
2.4 GHz, 5 GHz
No CPU
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Network adapter
External
SuperSpeed USB 3.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
1.2 Gbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode, WPS
Aerial
Antenna
Internal
Directivity
Omni-directional
Processor / Memory
No CPU
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
9.22 cm
2.9 cm
1.46 cm
10 - 90% (non-condensing)
