TP LINK Archer T2UH AC600 High Gain Wireless Dual Band USB Adapter
Quicklinx: 9Y18WS00 Mfr#: Archer T2UH
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
802.11ac - The Next Generation of WiFi
TP-LINK's Archer T2UH comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds. With 433Mbps wireless speeds over the crystal clear 5GHz band or 150Mbps over the 2.4GHz band, the Archer T2UH is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
AC600 Wireless Speed
The 5GHz 433Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4GHz 150Mbps Wi-Fi for normal use such as web surfing.
External Detachable High Gain Antenna
Archer T2UH features 3dBi external antenna which can be rotated and adjusted in different directions to fit various environments, significantly bringing better performance than adapters with internal antennas. For even more demanding applications, the antenna can be replaced with diverse antennas to show even greater flexibility and wider wireless coverage.
The Best of Both Bands
TP-LINK's Archer T2UH is an AC600 Wireless Dual Band USB Adapter, enabling you to easily access crystal clear 5GHz connections or legacy 2.4GHz connections, upgrading your notebook or PC's wireless capabilities.
Bundled USB Extension Cable
Archer T2UH equipped with the 1m USB 2.0 extension cable, which extend the USB connection length, making it more convenient to plug the USB device in & out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
  • Wi-Fi
    TP-LINK's Archer T2UH comes with the Wi-Fi faster than wireless N speeds. With ultra high wireless speeds, the Archer T2UH is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
  • High wireless speed
    It's perfect for HD video streaming and lag-free online gaming, while using Wi-Fi for normal use such as web surfing.
  • External detachable high gain antenna
    Archer T2UH features external antenna which can be rotated and adjusted in different directions to fit various environments, significantly bringing better performance than adapters with internal antennas. For even more demanding applications, the antenna can be replaced with diverse antennas to show even greater flexibility and wider wireless coverage.
  • Bundled USB extension cable
    Archer T2UH equipped with the USB 2.0 extension cable, which extend the USB connection length, making it more convenient to plug the USB device in and out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
TP-Link Archer T2UH - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
9.35 cm x 2.6 cm x 1.1 cm
Wi-Fi 5
Data Transfer Rate
600 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Spread Spectrum Method
OFDM
Data Transfer Rate
600 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode, WPS
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
3 dBi
1 x aerial - RP-SMA
1 x USB extension cable (external)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
9.35 cm
2.6 cm
1.1 cm
10 - 90% (non-condensing)
