Claim a FREE AC Wireless adapter with this purchase!
TP-LINK's Archer D7 AC1750 Wireless Dual Band Gigabit ADSL2+ Modem Router is a combined wired/wireless network connection device with integrated wireless router and ADSL modem, reducing hassle of configuration and saving space. Featuring a variety of features and rich functionality, Archer D7 is the perfect hub of your home or business network.
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer D7 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
1.75Gbps Concurrent Dual Band - More Bandwidth, Less Interference
With 1.3Gbps wireless speeds over the crystal clear 5GHz band and 450Mbps over the 2.4GHz band, Archer D7 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
3 External Antennas and High Power Amplifiers - Fully Expanded Coverage
With 3 detachable dual band external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with high speed and stability. Furthermore, its high power amplifiers provide stronger signals in every direction with better coverage. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections - Ultrafast Data Transfer Speeds
With one gigabit LAN/WAN port and 3 gigabit LAN ports, the Archer D7 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
Dual Multifunctional USB Ports - Easy Storage and Sharing
Using the Archer D7's two multi-functional USB 2.0 ports, you can share a printer with multiple computers and devices on your network and can also share files & media at home or via the ftp server while away from home.
Interchangeable LAN/WAN Port - Versatile Connectivity
The Archer D7 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
Easy Setup
Included in the resource CD, TP-LINK's optimized configuration utility can help you complete the entire software installation and wireless network settings in just a few minutes. it's worth mentioning that with built-in intelligent auto-detection, Archer D7 is capable of automatically figuring out which connection type to use in a flash, saving you the trouble of searching for your connection information type and speeding up the setup process.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
IPv6 Supported
Archer D7 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
802.11ac - the next generation of Wi-Fi
TP-LINK's Archer D7 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause. -
1.75 Gbps concurrent dual band - more bandwidth, less interference
With 1.3 Gbps wireless speeds over the crystal clear 5 GHz band and 450 Mbps over the 2.4 GHz band, Archer D7 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5 GHz band - all at the same time. -
3 external antennas and high power amplifiers - fully expanded coverage
With 3 detachable dual band external antennas combined with higher quality antenna technology, you can experience excellent wireless performance with high speed and stability. Furthermore, its high power amplifiers provide stronger signals in every direction with better coverage. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office. -
Full gigabit wired connections - ultrafast data transfer speeds
With one gigabit LAN/WAN port and 3 gigabit LAN ports, the Archer D7 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming. -
Dual multifunctional USB ports - easy storage and sharing
Using the Archer D7's two multi-functional USB 2.0 ports, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files. -
Interchangeable LAN/WAN port - versatile connectivity
The Archer D7 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary. -
Easy setup
Included in the resource CD, TP-LINK's optimized configuration utility can help you complete the entire software installation and wireless network settings in just a few minutes. It is worth mentioning that with built-in intelligent auto-detection, Archer D7 is capable of automatically figuring out which connection type to use in a flash, saving you the trouble of searching for your connection information type and speeding up the setup process. -
Guest network
Guest network access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data. -
IPv6 supported
Archer D7 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of services and improved user experience.
- TP-Link Archer D7 AC1750 - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.75 Gbps
- Capacity
- IPSec VPN tunnels: 10
- TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, FTP, DHCP, DDNS
- Routing Protocol
- IGMPv2, IGMP, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, CLI, TR-069
- Firewall protection, DMZ port, NAT support, DoS attack prevention, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, wireless bridge mode, bandwidth control, IPv4 support, port triggering, DHCP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 22.9 cm x 16 cm x 3.7 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
- Wireless router - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.75 Gbps
- Capacity
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
- Status Indicators
- Power, WLAN, link/activity, USB
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
- WAN / LAN: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , Antenna: 3 x RP-SMA
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Gain Level
- 3 dBi
- Power Device
- External power adapter
- Included Accessories
- ADSL splitter
- Cables Included
- 1 x network cable , 1 x phone cable
- Software Included
- Drivers & Utilities
- OS Required
- 22.9 cm
- 16 cm
- 3.7 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
