Coming with the next generation Wi-Fi standard - 802.1 lac, 3 times faster than wireless N speeds in a single stream, Archer D20 delivers a combined wireless data transfer rate of up to 750Mbps with 300Mbps over 2.4GHz and 433Mbps over 5GHz. 802.1 lac also brings higher power efficiency and robust security, making Archer D20 a perfect hub for your home or small office network.
Premium Wireless Network experience
Simultaneous dual band offers the flexibility of two dedicated networks for basic tasks and bandwidth- intensive applications respectively. Two dual band external antennas deliver greater range and perfor-mance.5GHz2.4GHz -
Easy USB storage and sharing
Using the Archer D20's multi-functional USB 2.0 port, you can share a printer with multiple computers and devices on your network and can share files & media at home or via the FTP server while away from home. -
Interchangeable LAN/WAN Port
The Archer D20 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary. -
Guest Network
Guest Network Access provides another secure Wi-Fi access for guests sharing your home or office network. -
Parental Control
Parental Controls allow parents or administrators to establish restricted access policies for children or staff. -
IPv6 Supported
The Archer D20 supports IPv6, the next generation of Internet protocol, helping you to future-proof your network. -
Easy Network management - TP-LINK Tether
TP-LINK Tether provides the easiest way to access and manage your router with your iOS or Android devices. From setup to parental control, Tether provides a simple, intuitive user interface to see what the status of your router is, who's online and what their privileges are. More models of the router can be configured with TP-LINK Tether. -
Install and manage more easily
TP-LINK's innovative web UI (User Interface) is designed into 3 different modules according to different user demands: Quick Setup, Basic and Advanced. The idea behind this is to ensure that everyone's home network installation and management experience is both quick & hassle free. This is evident in the fact that the web UI's basic setup can be completed within an astounding 15 seconds.
- TP-Link Archer D20 - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 750 Mbps
- Capacity
- IPSec VPN tunnels: 10
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, FTP, DHCP, DDNS
- Routing Protocol
- IGMPv2, IGMP, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, CLI, TR-069
- Firewall protection, DMZ port, NAT support, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, WDS support, URL filtering, parental control, IP address filtering, WMM support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, wireless bridge mode, bandwidth control, IPv4 support, port triggering, DHCP relay, DHCP client, DoS, SYN Flooding, Ping of Death
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 20.2 cm x 14.1 cm x 3.37 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 750 Mbps
- Capacity
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
- Status Indicators
- Power, WLAN, link/activity, USB
Line Properties
- Framing Format
- ANSI T1.413i2
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.995.1
- Phone line: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Power Device
- External power adapter
- Included Accessories
- ADSL splitter
- Cables Included
- 1 x network cable , 1 x phone cable
- Software Included
- Drivers & Utilities
- OS Required
- 20.2 cm
- 14.1 cm
- 3.37 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
