TP LINK Archer C9 AC1900 Wireless Dual Band Gigabit Router
Quicklinx: 9Y19WS00 Mfr#: Archer C9
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 1.9Gbps
Rackmount or External: External
  • IEEE 802.11n
£101.55 ex VAT
£121.86 inc VAT
Super-Fast Transfer Speeds Providing a Superior WiFi Experience
Archer C9 comes with the next generation 11ac Wi-Fi standard, offering total data transfer speeds up to 1.9Gbps. With 1.3Gbps over the clearer 5GHz frequency, and 600Mbps using two wireless chips to maximize performance over the 2.4GHz frequency, your whole home will get excellent wireless coverage. Ultra-fast 1GHz dual-core CPU function as a great `heart' for fast, stable and responsive performance with Wi-Fi, Ethernet and USB devices. The outstanding Gigabit WiFi and Gigabit wired connections are ideal for bandwidth sensitive applications like streaming in HD and seamless online gaming. With Archer C9 you get a super-fast, high performance connected home.
Greater Coverage and Reliable Wi-Fi
Three dual band antennas and high-powered amplifiers ensure continuous Wi-Fi signal to all your devices while boosting widespread coverage throughout your home.
Beamforming Technology for Laser-Focused Wi-Fi
Beamforming concentrates the Wi-Fi signal towards your Wi-Fi devices, focusing the data transmission to where you need it the most. Superior Wi-Fi bandwidth utilization increases Wi-Fi range, delivering highly targeted and efficient Wi-Fi connections.
Dual USB Ports for Easy Sharing
With a USB 3.0 port and a USB 2.0 port, it's easy to share local printers, files and media within the network and between devices. Utilize the FTP server to access files stored on the router while away home. Take advantage of USB 3.0 with 10x faster speed than traditional USB 2.0.
Tether APP
TP-LINK Tether provides the easiest way to access and manage your router with your iOS devices.
Elegant Appearance
The sophisticated design enhances every home. Its gentle curves, excellent crafting and remarkable quality exudes style and elegance without compromising on excellent performance.
  • Super fast transfer speeds providing a superior Wi-Fi experience
    Archer C9 comes with advanced Wi-Fi, offering lightning-fast data transfer speeds. With clearer frequency and higher performance, your whole home will get excellent wireless coverage. The outstanding Gigabit Wi-Fi and Gigabit wired connections are ideal for bandwidth-sensitive applications like streaming high-definition content and seamless online gaming. With Archer C9 you get a super-fast, high performance connected home.
  • Greater coverage and reliable Wi-Fi
  • Dual USB ports for easy sharing
    With a USB 3.0 port and a USB 2.0 port, it's easy to share local printers, files and media within the network and between devices. Utilize the FTP server to access files stored on the router while away home. Take advantage of USB 3.0 with much faster speed than traditional USB 2.0.
  • Elegant appearance
  • Guest Network feature
    Guest Network Access provides secure access to guests sharing your Wi-Fi network.
  • Parental Control tool
    Parental Controls allow parents or administrators to deploy restricted access for children or staff. With URL blocking, you can easily set up a black or white list to limit the level of web access.
  • Easy setup
    Quick and hassle-free installation via the web configuration utility from any laptop, smartphone or tablet.
TP-Link ARCHER C9 AC1900 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Performance
Maximum throughput (2.4 GHz): 600 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DNS, DDNS
Firewall protection, DMZ port, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, parental control, IP address filtering, domain blocking, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, static IP mode, wireless bridge mode, reset button, bandwidth control, IPv4 support, port triggering, dynamic IP mode, IP-MAC binding, DHCP client, DHCP reservation, Guest Zone support, beamforming technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
22.1 cm x 8.6 cm x 16.85 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Performance
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1900
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1 GHz
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
External power adapter
1 x network cable
Software Included
Drivers & Utilities
22.1 cm
8.6 cm
16.85 cm
10 - 90% (non-condensing)
9Y19 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.02
9Y19 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.53
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1.9Gbps
Brand: TP LINK
Price Range Ex VAT: 100 - 150
