TP LINK Archer C80 AC1900 Dual-Band Wi-Fi Router
Quicklinx: FT7FWS00 Mfr#: Archer C80
Type: Wireless router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11n + 4 more
Speed: 1.9Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
£65.15 ex VAT
£78.18 inc VAT
With 3x3 MIMO, Archer C80 is capable of transmitting and receiving data on three streams. 3x3 capable pair perfectly with C80 to perform at max with much higher efficiency than 2x2 MIMO routers.
  • Incredible home Wi-Fi
    Archer C80 delivers high-performance and affordable home Wi-Fi. Handle simple tasks like sending e-mails or web browsing on the 2.4 GHz band and bandwidth-intensive tasks like online gaming or streaming on the 5 GHz band.
  • Broader coverage throughout your home
    Access your entertainment from every corner of your home with 4 external high-performance antennas. Beamforming technology detects devices and concentrates wireless signal strength towards them, even if they are far away or low powered.
  • Connect more devices simultaneously
    Archer C80 helps your devices achieve optimal performance by making communication more efficient with MU-MIMO technology. Multiple devices are able to send and receive data.
  • Increased efficiency in Wi-Fi distribution
    Smart connect helps your router automatically switch each device's connection to the best available Wi-Fi band.
TP-Link Archer C80 V1 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Performance
Maximum throughput (2.4 GHz): 600 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Firewall protection, DMZ port, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, manageable, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, IP address filtering, Access Control List (ACL) support, Wireless Guest Services, Samba support, FTP server, static IP mode, port forwarding, wireless bridge mode, port triggering, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, DHCP reservation, beamforming technology, domain filter, wireless access scheduling, DMZ support, 3x3 MIMO technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
21.5 cm x 11.7 cm x 3.2 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.9 Gbps
Performance
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1900
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
4
Directivity
Omni-directional
External power adapter
1 x network cable
Software Included
Drivers & Utilities
21.5 cm
11.7 cm
3.2 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 1.9Gbps
Brand: TP LINK
