TP LINK Archer C8 AC1750 Dual Band Wireless Cable Router
Quicklinx: 9XFBWS00 Mfr#: Archer C8
  • IEEE 802.11n
Super Fast Transfer Speeds Providing a Superior WiFi Experience
Archer C8 comes with the next generation 11ac Wi-Fi standard, offering total data transfer speeds achieving up to 1.75Gbps, with 1.3Gbps over the clearer 5GHz channel, and 450Mbps over the 2.4GHz Channel. Ultra-fast 800MHz dual-core CPU function as a great `heart' for fast, stable and responsive performance with Wi-Fi, Ethernet and USB devices. Whole home coverage with excellent Gigabit WiFi are ideal for bandwidth intensive applications such as HD video streaming and online gaming, allowing you to enjoy a super-fast connected home.
Greater Coverage and Reliable Wi-Fi
Archer C8's 3 dual band antennas with high powered signal amplifiers guarantee continuous Wi-Fi speeds to all your devices while boosting Wi-Fi coverage throughout your home.
Beamforming Technology for Efficient WiFi
Archer C8's beamforming technology locate your connected devices and boost wireless signal strength in those directions, delivering a more targeted and highly efficient wireless connection.
Dual USB Ports for Easy Sharing
With one ultrafast USB 3.0 port and one USB 2.0 port, you can easily access and share a printer locally and files & media with networked devices or remotely via the router's FTP server. The USB 3.0 port provides up to 10x faster USB hard drive access than legacy USB 2.0 connections.
Gigabit Wired Connections for Ultrafast Data Transfer Speeds
Full shielded Gigabit WAN-LAN ports can achieve blazing WAN to LAN throughput of up to 1000Mbps. Archer C8 is a powerful hub to support a robust and extremely fast wired network.
Modern and Elegant Appearance
Archer C8's novel shape catches people's eyes with its beauty, decorating a modern home. With numerous ventilation holes in the back, uninterrupted high speed performance is guaranteed. With gentle curves, excellent crafting and remarkable quality, its design exudes fashion and elegance.
  • Super fast transfer speeds providing a superior Wi-Fi experience
    Archer C8 comes with the 11ac Wi-Fi standard, offering total data transfer speeds achieving up to 1.75 Gbps, with 1.3 Gbps over the clearer 5 GHz channel, and 450 Mbps over the 2.4 GHz channel. Ultra-fast 800 MHz dual-core CPU function as a great 'heart' for fast, stable and responsive performance with Wi-Fi, Ethernet and USB devices. Whole home coverage with excellent Gigabit Wi-Fi are ideal for bandwidth intensive applications such as HD video streaming and online gaming, allowing you to enjoy a super-fast connected home.
  • Greater coverage and reliable Wi-Fi
  • Beamforming technology for efficient Wi-Fi
    Archer C8's beamforming technology locates your connected devices and boost wireless signal strength in those directions, delivering a more targeted and highly efficient wireless connection.
  • Dual USB ports for easy sharing
    With one ultra fast USB 3.0 port and one USB 2.0 port, you can easily access and share a printer locally and files and media with networked devices or remotely via the router's FTP server. The USB 3.0 port provides up to 10x faster USB hard drive access than legacy USB 2.0 connections.
  • Gigabit wired connections for ultra fast data transfer speeds
    Full shielded Gigabit WAN-LAN ports can achieve blazing WAN to LAN throughput of up to 1000 Mbps. Archer C8 is a powerful hub to support a robust and extremely fast wired network.
  • Modern and elegant appearance
TP-Link Archer C8 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
DoS attack prevention, print server, MAC address filtering, IPv6 support, WDS support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
22.1 cm x 8.6 cm x 16.85 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Built-in Devices
Led panel
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A , Antenna: 3 x
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
Software Included
Drivers & Utilities
22.1 cm
8.6 cm
16.85 cm
10 - 90% (non-condensing)
9XFB C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
