TP LINK Archer C5400X WiFi Tri-band AC5400 Router
Quicklinx: F9JVWS00 Mfr#: Archer C5400X
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11a, IEEE 802.11g, Ethernet, Fast Ethernet + 4 more
Speed: 5334Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
Hurry, only 1 left in stock!
£255.71 ex VAT
£306.85 inc VAT
Wi-Fi Made for Gamers – Dominate the competition with Wi-Fi made for gamers and gaming families.
GeForce NOW Recommended – Best latency killer for cloud gaming GeForce NOW.
Battle-Tested Processing – 1.8 GHz 64-bit quad-core CPU, three co-processors and 1 GB RAM.
Prioritized Performance – Set the QoS engine to gaming mode to keep your connection fast when everyone is online.
Connect More Devices – Tri-band Wi-Fi speeds up to 5400 Mbps over one 2.4 GHz (1000 Mbps) and two 5 GHz (2167 Mbps) bands.1
Adept Multi-Tasking – MU-MIMO and Airtime Fairness serve multiple connections and distribute Wi-Fi and optimize performance.2
Far-Reaching Coverage – RangeBoost strengthens reception and beamforming sends targeted Wi-Fi to keep devices connected at farther distances than other routers.
Doubled Wired Speeds – Link Aggregation teams two of the eight Gigabit LAN ports or one LAN with the WAN port to double the connection speed.
Comprehensive Security – Powerful antivirus works from the router to protect all your devices from cyber threats with HomeCare
  • Intelligent traffic prioritization
    The Archer C5400X conquers lag, immediately eradicating it from your gaming experience. Its dynamic optimization engine automatically identifies gaming traffic to give you the tactical advantage during heated raids, PvP encounters and ranked matches. When you aren't gaming, fast-track streaming to watch immersive 4K movies.
  • Full-throttle wireless performance
    The Archer C5400X employs MU-MIMO and Airtime Fairness to balance the requests of every device with speed and precision. Calibrated metrics and sophisticated algorithms determine how the router divides air time and distributes dedicated Wi-Fi streams to each device, leaving you to focus on taking down the opposition instead of fighting your allies for bandwidth.
  • Far-reaching Wi-Fi range
    Game from the basement to the garage and even the backyard with RangeBoost, which strengthens reception quality to reinforce connections in your home and keep both older and newer devices connected at greater distances than other routers.
TP-Link Archer C5400X - wireless router - Wi-Fi 5 - desktop
Wireless router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
5334 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
Routing Protocol
Static IP routing
Print server, IPv6 support, VPN passthrough, parental control, firmware upgradable, WMM support, virtual server support, WPS, DHCP server, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, DHCP client, VPN Server, MU-MIMO technology, Tri-Band Smart Connect technology, Broadcom NitroQAM technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.05 cm x 24.05 cm x 5.53 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
5334 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC5400
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.8 GHz
RAM
1 GB
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
8
External power adapter
1 x network cable
24.05 cm
24.05 cm
5.53 cm
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 5334Mbps
Brand: TP LINK
