TP LINK Archer C5400 Tri-Band MU-MIMO Gigabit Router
Quicklinx: CM9LWS00 Mfr#: Archer C5400
  • IEEE 802.11n
Archer C5400 delivers combined tri-band Wi-Fi speeds, establishing a network, that can connect more devices without slowing down. Smart Connect helps devices run even faster by assigning them to the channel to balance network demand.
  • Full technology empowers home entertainment
    The router serves as a powerful entertainment hub for your home, that is capable of supporting multiple simultaneous HD video streams, online gaming, and other online activities without slowing down. Superior range and coverage keeps your devices connected, near or far.
  • Maximized range and efficiency
    The antennas with Beamforming technology detect the locations of your connected devices and concentrate wireless signal strength toward them. This makes all of your connections more efficient and stable, improving network performance, even in medium-sized offices and public cafes.
  • Large file sharing
    External hard drives can connect directly to the Archer C5400 via its USB 3.0 and 2.0 ports, making it easy to share large files, photos, music and video across your network.
  • Smooth gaming and streaming
    To help your wired devices achieve peak performance for smooth gaming and streaming, the Gigabit Ethernet ports operate faster.
TP-Link Archer C5400 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
5334 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS, Bigpond
Routing Protocol
Static IP routing
DoS attack prevention, print server, IPv6 support, VPN passthrough, antivirus analysis, parental control, IP address filtering, firmware upgradable, WMM support, ACL support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, IP-MAC binding, DHCP client, VPN Server, MU-MIMO technology, Tri-Band Smart Connect technology, Broadcom NitroQAM technology, domain filter, black list, white list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
23 cm x 23 cm x 4.3 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8, Windows 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
5334 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC5400
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.4 GHz
Line Properties
Line Coding Format
1024 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
8
External power adapter
1 x network cable
23 cm
23 cm
4.3 cm
10 - 90% (non-condensing)
