TP LINK Archer C3150 Wireless MU-MIMO Gigabit Router
Quicklinx: CM9MWS00 Mfr#: Archer C3150
  • IEEE 802.11n
Hurry, only 1 left in stock!
£134.71 ex VAT
£161.65 inc VAT
With combined speeds of up to 3150Mbps, the Archer C3150 easily handles demanding activities at the same time. The router uses enhanced Wi-Fi technology to create a faster, stronger, more reliable wireless network for your home. With the Archer C3150, lag, dropped connections, and dead zones will become a thing of the past. The Archer C3150 boasts a powerful combination of a Broadcom NitroQAM technology and 4-Stream technology. This provides the speed and performance that you need to support your most demanding online applications, including simultaneous 4K streaming and online gaming. The Archer C3150 does more than just create faster Wi-Fi, it helps your devices achieve optimal performance by making communication more efficient. With MU-MIMO technology, the Archer C3150 can provide four simultaneous data streams, allowing all connected devices to achieve faster speeds.
Archer C3150 can support many devices when you invite friends to your large house to entertain. It can maintain multiple simultaneous HD streaming, online gaming and other content consumption without lag. The Archer C3150 can provide a maximized coverage and enable your devices to stay covered, near or far as it. Don't let your mobile lifestyle stop the streaming and enjoy your home party. The Archer C3150 features a powerful processor. This unlocks the full potential of MU-MIMO and 4-Stream technologies, helping your dual band router maximize its performance potential. Four high-performance dual band antennas and high-powered amplifiers help create a strong, far-reaching network for your home. Beamforming technology focuses the Wi-Fi transmission in the direction of your connected devices, concentrating the signal where you need it the most. This allows you to enjoy fast, stable Wi-Fi in every part of your home, as well as on the patio, by the pool, and even in the yard.
  • Making amazing speed a reality
  • NitroQAM and 4-Stream for maximum Wi-Fi speed
  • More connections and more speed for everyone
  • Extraordinary home entertainment
  • The power at the heart of your router
  • Coverage for your entire home
  • A router you can show off
    An elegant, minimalist design allows the Archer C3150 to be integrated seamlessly into the decor of any room. The LED indicators can be switched off to prevent distraction at night when placed in bedrooms or common spaces.
  • Plug into sharing, plug into stability
    You can quickly and easily share photos, music, and other files with family and friends. Just connect an external hard drive to the Archer C3150's USB 3.0 port or USB 2.0 port and immediately start enjoying lightning-fast transfers. To help your wired devices reach peak performance for smooth gaming and streaming, you can also create fast, stable wired connections using the four Gigabit Ethernet ports, which transfer data at speeds up to 10x higher than standard Ethernet ports.
TP-Link Archer C3150 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3167 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP, DDNS
VPN support, dynamic DNS server, print server, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, DHCP client, MU-MIMO technology, SmartConnect Technology, beamforming technology, Broadcom NitroQAM technology, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
26.38 cm x 19.78 cm x 3.73 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3167 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.4 GHz
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable
26.38 cm
19.78 cm
3.73 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 3167Mbps
Brand: TP LINK
Price Range Ex VAT: 100 - 150
