TP LINK Archer C20i AC750 Wireless Dual Band Router
Quicklinx: 9SVVWS00 Mfr#: C20i
  • IEEE 802.11n
TP-LINK's Archer C20i comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
733Mbps Dual Band Connections for Lag-Free Work and Entertainment
With 433Mbps wireless speeds over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, Archer C20i offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
Stable Omnidirectional Signal and Superior Coverage
With 3 antennas combined with higher quality antenna technology, you can experience excellent wireless performance with stable signal in every direction and high speed across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Easy USB Storage and Sharing
With the USB port, you can share a printer locally and files & media with networked devices or remotely via FTP server.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
Parental Control
Parental Control allows parents or administrators to establish restricted access policies for children or staff.
Easy Setup
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported
Archer C20i supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
  • 802.11ac - the next generation of Wi-Fi
  • 733 Mbps dual band connections for lag-free work and entertainment
    With 433 Mbps wireless speeds over the crystal clear 5 GHz band and 300 Mbps over the 2.4 GHz band, Archer C20i offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5 GHz band - all at the same time.
  • Stable omnidirectional signal and superior coverage
  • Easy USB storage and sharing
    With the USB port, you can share a printer locally and files and media with networked devices or remotely via FTP server.
  • Guest network
    Guest network access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
  • Parental control
    Parental control allows parents or administrators to establish restricted access policies for children or staff.
  • Easy setup
  • IPv6 supported
    Archer C20i supports IPv6, which is the foundation of the Internet and enables a range of services and improved user experience.
TP-Link Archer C20i AC750 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IP routing
Firewall protection, DMZ port, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, print server, MAC address filtering, IPv6 support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, FTP server, bandwidth control, IPv4 support, port triggering, dynamic IP mode, DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
11.3 cm x 6 cm x 17.1 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC750
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
1 x network cable
Software Included
Drivers & Utilities
11.3 cm
6 cm
17.1 cm
10 - 90% (non-condensing)
