TP LINK Archer AX6000 WiFi 6 Dual Band Router
Quicklinx: F9JWWS00 Mfr#: Archer AX6000
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11g, Ethernet, Fast Ethernet, IEEE 802.11b + 6 more
Speed: 4804Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
10 In Stock
£233.33 ex VAT
£279.99 inc VAT
With OFDMA and MU-MIMO technology, Archer AX6000 provides higher capacity and throughput in dense usage environments, greatly increasing the number of connected devices.
  • Far-reaching Wi-Fi coverage
    8 high-gain external antennas deliver a strong Wi-Fi signal throughout your home. Beamforming delivers a stronger and far-reaching network.
  • Highly efficient
    OFDMA increases average throughput in high-density scenarios.
  • Intelligent connection
    Band steering directs clients to less congested band and airtime fairness optimizes the time usage.
TP-Link Archer AX6000 - wireless router - Wi-Fi 6 - desktop
Wireless router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Performance
Maximum data rate (2.4 GHz): 1148 Mbps , Maximum data rate (5 GHz): 4804 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, parental control, IP address filtering, WMM support, virtual server support, WPS, DHCP server, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
26.1 cm x 26.1 cm x 6.02 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
1.8 GHz
RAM
1 GB
Flash Memory
128 MB
Status Indicators
Port status, power, link/activity
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 2.5GBase-T - RJ-45 , USB 3.0: 1 x , USB 3.0: 1 x 24 pin USB-C
Aerial
Aerial
External integrated
Antenna Qty
8
External power adapter
1 x network cable
26.1 cm
26.1 cm
6.02 cm
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11a
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ax (Wi-Fi 6)
Standards: IEEE 802.11ac
Speed: 4804Mbps
Brand: TP LINK
