The Archer C4000 powers through every service, thread and application running on your network with a 1.8 GHz 64-bit quad-core CPU that delivers fast, lag-free connections to gaming, streaming and mobile devices.
Quad-core processing for powerful performance
The Archer C4000 powers through every service, thread and application running on your network with a 1.8 GHz 64-bit quad-core CPU that delivers fast, lag-free connections to gaming, streaming and mobile devices. -
Entertain every member at the same time
Buffering will never be a problem from now on. With Tri-band and MU-MIMO Technology, the Archer C4000 wireless router can communicate with multiple devices at the same moment, sending and receiving data on the best available band. So you can still enjoy a non-stop MOBA or FPS game when your families are watching 4K videos online. -
Far-reaching Wi-Fi coverage
High-performance antennas with powered amplifier create strong Wi-Fi signal across your home. RangeBoost technology greatly improves ability to detect devices that are further away or low-powered, giving your network even greater coverage. Beam forming focuses on wireless signals towards connected devices for stable Wi-Fi. -
Gigabit wired speeds and link aggregation
All Gigabit Ethernet ports (1 WAN+ 4 LAN) bring wired speeds to the maximum. Plug your PCs, smart TVs and game consoles into one of the four Gigabit Ethernet ports for fast and reliable wired connections.
- TP-Link Archer C4000 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Data Transfer Rate
- 4000 Mbps
- PPTP, L2TP, PPPoE, DHCP, DDNS
- VPN support, dynamic DNS server, print server, IPv6 support, parental control, WMM support, WPS, DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, DHCP client, MU-MIMO technology, SmartConnect Technology, beamforming technology, Broadcom NitroQAM technology, WDS bridge
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 20 cm x 20 cm x 3.9 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 4000 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC4000
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Processor
- 1.8 GHz
Line Properties
- Line Coding Format
- 1024 QAM
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 6
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- OS Required
- 20 cm
- 20 cm
- 3.9 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
