TP LINK Archer AC1200 Dual-Band Wi-Fi Router
Quicklinx: FT7GWS00 Mfr#: Archer C1200
  • IEEE 802.11n
£51.60 ex VAT
£61.92 inc VAT
The Archer C1200 creates a reliable, blazing-fast network, using powerful 802.11ac Wi-Fi technology. Now you can enjoy streaming HD video and lag-free online gaming on the clear 5 GHz band while using the 2.4 GHz band for everyday tasks, such as checking email and web browsing.
  • External antennas greatly expand wireless coverage
    Three external antennas with advanced connection technology allow you to maintain impressive speeds, even over greater distances. This means, that you can enjoy incredible wireless coverage and reliability in any part of your large home or office.
  • Full Gigabit wired connections
    With four built-in Gigabit Ethernet ports, the Archer C1200 can provide fast, stable connections to all of your favorite wired devices, including game consoles, smart TVs, DVRs, and more.
  • Versatile USB sharing
    With the USB 2.0 port, you can share printers, files, and media with numerous devices on your local network or via FTP server from anywhere in the world.
TP-Link Archer C1200 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS, Bigpond
Routing Protocol
Static IP routing
DoS attack prevention, print server, MAC address filtering, IPv6 support, parental control, firmware upgradable, WMM support, ACL support, QoS, virtual server support, WPS, DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, SPIF, IP-MAC binding, DHCP client, VPN Server, QSS, DMZ support, black list, white list
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.3 cm x 3.25 cm x 16.06 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1, Windows 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
3
External power adapter
1 x network cable
24.3 cm
3.25 cm
16.06 cm
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11g
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 1200Mbps
Brand: TP LINK
