The Archer A5 lets your PC or laptop enjoy connections 3x faster than Wireless N with Wireless AC technology. With 300Mbps over the 2.4GHz band and 867Mbps over the crystal clear 5GHz band, the Archer A5 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
Four well-ordered antennas make all of your connections more efficient and stable. Advanced antenna technology increases the receiving sensitivity to enlarge Wi-Fi coverage for your home.
Supervise children and staff with responsible access, controlled by parents or administrators. Use key words to easily set up a black list and limit the level of web access.
Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
Captive portal helps maintain only authorized guests to use the network, presenting devices with a convenient, user-friendly authentication method to grant Wi-Fi access. Easily share your facebook account to anyone who connects to your network.
Set up the Archer A5 in minutes thanks to its intuitive web interface and the powerful Tether app. Tether also lets you manage its network settings from any Android or iOS device, including parental controls and access control.
High-speed dual band Wi-Fi for better connections
The Archer A5 lets your PC or laptop enjoy connections 3x faster than Wireless N with Wireless AC technology. With 300Mbps over the 2.4GHz band and 867Mbps over the crystal clear 5GHz band, the Archer A5 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks. -
Innovative antenna design for maximum coverage
Four well-ordered antennas make all of your connections more efficient and stable. Advanced antenna technology increases the receiving sensitivity to enlarge Wi-Fi coverage for your home. -
Easy parental control
Supervise children and staff with responsible access, controlled by parents or administrators. Use key words to easily set up a black list and limit the level of web access. -
Guest network access
Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security. -
Efficient guest authentication with Facebook
Captive portal helps maintain only authorized guests to use the network, presenting devices with a convenient, user-friendly authentication method to grant Wi-Fi access. Easily share your facebook account to anyone who connects to your network. -
Easy setup and use
- TP-Link Archer A5 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1200 Mbps
- PPTP, L2TP, IPSec, PPPoE, DHCP
- Routing Protocol
- Static IP routing
- Firewall protection, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, reset button, bandwidth control, IPv4 support, port triggering, IP-MAC binding, DHCP client, WDS bridge
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 22.987 cm x 14.419 cm x 3.685 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1 / 10
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1200 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1200
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Status Indicators
- Port status, power, link/activity
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 4
- Directivity
- Omni-directional
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- OS Required
- 22.987 cm
- 14.419 cm
- 3.685 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
