TP LINK AC750 Mini Pocket Wi-Fi Router
Quicklinx: FT7KWS00 Mfr#: TL-WR902AC
Type: Wireless router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, IEEE 802.11a, IEEE 802.11b + 3 more
Speed: 733Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
More than 50 In Stock
£29.99 ex VAT
£35.98 inc VAT
Conveniently small and light to pack and take on the road, enjoy this router, creating Wi-Fi network via Ethernet, 3G/4G USB modem or WISP.
  • Dual-band Wi-Fi
    Strong, fast connection for HD streaming on all your devices.
  • One switch for multiple modes
    Perfect for Wi-Fi at home, your hotel room or on the road.
  • Flexible power
    MicroUSB port to an adapter, portable charger or laptop.
  • Versatile USB
    Suitable for file sharing or Internet access from a 3G/4G USB modem.
TP-Link TL-WR902AC - wireless router - Wi-Fi 5 - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
DMZ port, DoS attack prevention, dynamic DNS server, manageable, VPN passthrough, parental control, WMM support, ACL support, virtual server support, WPS, DHCP server, reset button, bandwidth control, IPv4 support, port triggering, SPIF, DHCP client, wireless extender mode, WDS bridge
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
7.4 cm x 6.7 cm x 2.2 cm
UNIX, Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WEP, 128-bit WPA
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
1 x network cable
7.4 cm
6.7 cm
2.2 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 733Mbps
Brand: TP LINK
