TP LINK AC2800 Wireless MU-MIMO VDSL/ADSL Modem Router
Quicklinx: DHJWWS00 Mfr#: ARCHER VR2800
Type: Wireless router
Connection Type: ADSL, ADSL2+, VDSL2 and Fibre
Standards: IEEE 802.11a, Ethernet, Fast Ethernet, Gigabit Ethernet + 4 more
Speed: 100Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£147.92 ex VAT
£177.50 inc VAT
MU-MIMO technology serves several devices at once, reducing wait time, increasing Wi-Fi throughput for every device, and making each stream more efficient. As a powerful DSL modem router, the Archer VR2800 supports super fast VDSL or ADSL broadband, as well a variety of other connection types. The LAN/WAN port accepts connections from cable modem or fiber modem, and both of the USB 3.0 ports support 3G/4G dongle connections for a perfect main or backup internet connection. Beamforming technology locates the connected devices and further improves the Archer VR2800's range and the signal strength to each mobile device, delivering a more reliable and efficient wireless connection. Separate Wi-Fi bands enable more devices to connect to your network without a drop in performance.
  • MU-MIMO
  • Versatile connectivity
  • Wi-Fi with Beamforming
  • Simultaneous dual band
TP-Link Archer VR2800 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
NAT support, ALG support, dynamic DNS server, print server, MAC address filtering, IPv6 support, parental control, IP address filtering, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, DHCP relay, Stateful Packet Inspection Firewall (SPIF), DHCP client, VPN Server, MU-MIMO technology, beamforming technology, Broadcom NitroQAM technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
26.38 cm x 19.78 cm x 3.73 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS, RCM
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.998.4, ITU G.993.5
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable , 1 x phone cable , 1 x phone splitter
26.38 cm
19.78 cm
3.73 cm
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 100Mbps
Brand: TP LINK
