With its clean, user-friendly design, The Touch P5's display interface provides an ideal portal through which to quickly access and manage your network settings. Now you can modify parental controls, add/remove devices from your network, and change guest access privileges with a few taps on your router's display. For added functionality, the touchscreen display can also function as a clock, when not in use.
The Wireless AC standard establishes a dual band network, allowing you to connect even more devices while still enjoying speeds of up to 1900 Mbps. This means that you can enjoy ultra high definition 4K streaming video and lag-free online gaming on the 5 GHz band, all while shopping, sending email, and browsing your favorite sites on the 2.4 GHz band.
Three external antennas with high-powered amplifiers greatly increase the Touch P5's range and signal stability. Beamforming technology further improves the router's coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room.
A simple, intuitive interface
With its clean, user-friendly design, The Touch P5's display interface provides an ideal portal through which to quickly access and manage your network settings. Now you can modify parental controls, add/remove devices from your network, and change guest access privileges with a few taps on your router's display. For added functionality, the touchscreen display can also function as a clock, when not in use. -
Wi-Fi technology
The wireless AC standard establishes a dual band network, allowing you to connect even more devices while still enjoying speeds of up to 1900 Mbps. This means that you can enjoy ultra high definition 4K streaming video and lag-free online gaming on the 5 GHz band, all while shopping, sending email, and browsing your favorite sites on the 2.4 GHz band. -
Superior Wi-Fi coverage for your home
Three external antennas with high-powered amplifiers greatly increase the Touch P5's range and signal stability. Beamforming technology further improves the router's coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room. -
Exquisite aesthetics, perfect for display in any location
The elegant design of the body gives your technology an aura of natural continuity in any environment. With the Touch P5, you can proudly integrate a gracefully designed router into your personal decor.
- TP-Link Touch P5 AC1900 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.9 Gbps
- Performance
- Maximum throughput (2.4 GHz): 600 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
- PPTP, L2TP, IPSec, PPPoE
- DMZ port, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, print server, MAC address filtering, IPv6 support, VPN passthrough, parental control, IP address filtering, firmware upgradable, WMM support, QoS, virtual server support, DHCP server, Samba support, FTP server, reset button, bandwidth control, IPv4 support, port triggering
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 28.4 cm x 15.7 cm x 5.2 cm
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.9 Gbps
- Performance
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1900
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
- Processor
- 1 GHz
- Built-in Devices
- 4.3" touch screen display
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- 28.4 cm
- 15.7 cm
- 5.2 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
