TP LINK AC1750 Wireless Dual Band Gigabit Router - V2.0
Quicklinx: 8PVPWS00 Mfr#: ARCHER C7
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 1.75Gbps
Rackmount or External: External
  • IEEE 802.11n
£55.48 ex VAT
£66.57 inc VAT
V2.0
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer C7 comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds and delivering a combined wireless data transfer rate of up to 1.75Gbps. With 1.3Gbps wireless speeds over the crystal clear 5GHz band and 450Mbps over the 2.4GHz band, the Archer C7 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
1.75Gbps Dual Band Connections for Lag-Free Work and Entertainment
The Archer C7 operates over both the 2.4GHz and 5GHz bands, ensuring amazing wireless performance. Simultaneous Dual Band offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
6 Antennas for Fully Expanded Coverage
With 3 external 5dBi antennas serving the 5GHz band and 3 internal antennas serving the 2.4GHz band combined with higher quality antenna technology, you can maintain high speeds across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
Full Gigabit Wired Connections for Ultrafast Data Transfer Speeds
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than standard Ethernet connections. The Archer C7 is a powerful hub to support a robust and extremely fast wired network.
Dual Multifunctional USB Ports for Storage and Sharing
With the two multi-functional USB 2.0 ports, you can share printers, files and media with different devices through your local network or via the ftp server while away from home.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network.
Easy Set-up
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just a few minutes.
IPv6 Supported
Archer C7 supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
  • 802.11ac - the next generation of Wi-Fi
    TP-LINK's Archer C7 comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds and delivering a combined wireless data transfer rate of up to 1.75 Gbps. With 1.3 Gbps wireless speeds over the crystal clear 5 GHz band and 450 Mbps over the 2.4 GHz band, the Archer C7 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
  • 1.75 Gbps dual band connections for lag-free work and entertainment
    The Archer C7 operates over both the 2.4 GHz and 5 GHz bands, ensuring amazing wireless performance. Simultaneous dual band offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4 GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5 GHz band - all at the same time.
  • 6 antennas for fully expanded coverage
    With 3 external 5 dBi antennas serving the 5 GHz band and 3 internal antennas serving the 2.4 GHz band combined with higher quality antenna technology, you can maintain high speeds across greater distances. This provides you with incredible wireless coverage and reliability from anywhere in your large home or office.
  • Full gigabit wired connections for ultrafast data transfer speeds
    With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10x faster than standard Ethernet connections. The Archer C7 is a powerful hub to support a robust and extremely fast wired network.
  • Dual multifunctional USB ports for storage and sharing
  • Easy set-up
TP-Link Archer C7 AC1750 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IP routing
Firewall protection, DMZ port, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, FTP server, bandwidth control, IPv4 support, port triggering, dynamic IP mode, DHCP client
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
24.3 cm x 16.06 cm x 3.25 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT / 2000 / XP, Microsoft Windows Vista / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA-PSK, WPA2-PSK
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable and internal
Antenna Qty
6
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
24.3 cm
16.06 cm
3.25 cm
10 - 90% (non-condensing)
8PVP C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
8PVP C2G 5m USB 2.0 A/B Cable - Black In Stock £5.24
8PVP C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.51
8PVP C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.71
8PVP C2G USB Superbooster Extender Kit In Stock £39.76
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1.75Gbps
Brand: TP LINK
Price Range Ex VAT: 50 - 100
