TP LINK AC1200 Wireless Dual Band ADSL2+ Modem Router
Quicklinx: BXNZWS00 Mfr#: Archer D50
  • IEEE 802.11n
Next generation AC Wi-Fi is three times faster than the wireless N standard. The Archer D50 delivers combined wireless data transfer speeds of up to 1200 Mbps, including 867 Mbps on the 5 GHz band and 300 Mbps on the 2.4 GHz band. With its increased efficiency and robust security, the 802.11ac standard offers a dramatically accelerated multimedia experience and easily serves multiple devices at the same time.
Simultaneous dual band Wi-Fi offers increased flexibility by creating two dedicated networks that can support all of your basic online tasks and bandwidth-intensive applications. The two dual band external antennas expand the router's range and enhance its performance.
The Archer D50's multi-functional USB 2.0 port allows you to share a printer with multiple computers and devices on your local network. It also lets you share files and media at home or from anywhere in the world via FTP.
  • Superfast wireless speed with the 802.11ac standard
  • Premium wireless experience
  • Easy USB storage and sharing
  • Dual connectivity
    The Archer D50 supports ADSL and Ethernet WAN inputs, providing you with the flexibility you need to get the most from your Internet connection. The ADSL port supports ADSL connections via any standard phone cable and the LAN/WAN port allows the Archer D50 to accept connections from fiber/cable modems using an Ethernet cable.
TP-Link ARCHER D50 AC1200 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 3-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
IPSec VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, DHCP
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, CLI, TR-069
NAT support, DoS attack prevention, ALG support, dynamic DNS server, manageable, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Samba support, FTP server, wireless bridge mode, reset button, IPv4 support, port triggering, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
20.2 cm x 14.1 cm x 3.36 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
PPTP, L2TP, DHCP
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1200
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS, RCM
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
WAN: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
ADSL splitter
1 x network cable , 1 x phone cable
Software Included
Drivers & Utilities
20.2 cm
14.1 cm
3.36 cm
10 - 90% (non-condensing)
