- TP-Link TL-WA1201 - radio access point
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
- Included Accessories
- PoE injector
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
- 40 cm x 25.5 cm x 7.2 cm
- 40 cm
- 25.5 cm
- 7.2 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- DHCP, IPv4, IPv6
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Wi-Fi Rating
- AC1200
- Wireless Distribution System (WDS) support, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, reset button, Wireless Client Mode, DHCP client, Captive Portal, wireless extender mode, MU-MIMO technology, passive PoE supported, WPS button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
Aerial
- Antenna
- External integrated
- Antenna Qty
- 4
- 1 x 1000Base-T - RJ-45
- PoE injector
- Cables Included
- 1 x network cable
- FCC, RoHS
- Power Device
- External power adapter
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
