Your basket is empty
TP LINK 8 Port Gigabit L2 Jetstream Managed Switch + 2 Gigabit SFP
Quicklinx: 7Z0BWS00 Mfr#: TL-SG3210
TP-LINK JetStream Gigabit L2 Lite managed switch TL-SG3210 provides 8 10/100/1000 Mbps ports. The switch provides high performance, enterprise-level QoS, advanced security strategies and rich layer 2 management features. Moreover, the switch also comes equipped with 2 Gigabit SFP slots, expanding your network flexibly. TL-SG3210 is the cost-effective network solution for the ideal small and medium business.
TL-SG3210 has robust security and management features. The IP-MAC-Port-VID Binding and Access Control List (ACL) functions protect against broadcast storms, ARP and Denial-of-Service (DoS) attacks, etc. Quality of Service provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive Layer 2 switch and gigabit capability, TP-LINK JetStream L2 Lite managed switch TL-SG3210 provides you the ideal access-edge solution.
TP-LINK JetStream TL-SG3210 - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 20 Gbps , Forwarding performance: 1.49 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Dynamic ARP Inspection (DAI), Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, SNMP trap
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.3av
29.4 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
10240 bytes
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
RADIUS
8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x management
Expansion Slots
2 (total) / 2 (free) x SFP (mini-GBIC)
Internal power supply
4 rubber feet
Rack Mounting Kit
Included
FCC
Software Included
Drivers & Utilities
29.4 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
