TP LINK 8-Port Gigabit Easy Smart Switch with 4-Port PoE
Quicklinx: BYDZWS00 Mfr#: TL-SG108PE
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE
24 in stock
£62.18 ex VAT
£74.61 inc VAT
The TL-SG108PE is an 8-port Gigabit Easy Smart switch with 4 PoE ports, represents a powerful upgrade from an unmanaged switch. It is designed specifically for small businesses that require simple network management and PoE function. The TL-SG108PE can connect and power up to four PoE devices, such as wireless access points (APs), IP cameras, and IP phones. Through its web-based user interface and management utility, the TL-SG108PE offers a variety of useful features, including network monitoring, traffic prioritization, and enhanced QoS. Additionally, with port-based, tag-based and MTU VLAN, TL-SG108PE can improve security and meet more network segmentation requirements.
  • Power over Ethernet
    4 of the 8 auto-negotiation RJ-45 ports (port 1 to port 4) of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af-compliant powered devices (PDs).
  • Effective management
    TL-SG108PE offers network monitoring for users to observe traffic behavior. Through its web-based user interface and management utility, the TL-SG108PE offers a variety of useful features, including network monitoring, traffic prioritization, and enhanced QoS. With Port Mirroring, Loop Prevention and Cable Diagnostics features, TL-SG108PE can identify and even locate connection problems on your business network. Moreover, administrators can designate the priority of the traffic based on port priority, 802.1p priority and DSCP priority, to ensure that voice and video are always clear, smooth and lag-free. Additionally, to improve security and network performance, TL-SG108PE supports MTU VLAN, port-based VLAN and 802.1Q-based VLAN functions.
  • Easy to use
    TL-SG108PE is easy to use and manage. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device and intelligently adjusts for compatibility and optimal performance. Its compact size makes it ideal for desktops with limited space while also being rack-mountable, convenient and safe. Dynamic LED lights provide real-time work status display and basic fault diagnosis.
TP-Link Easy Smart TL-SG108PE - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (4 PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
55 W
Performance
Forwarding performance: 11.9 Mpps
Virtual interfaces (VLANs): 32
MAC Address Table Size
4K entries
Jumbo Frame Support
15KB
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Quality of Service (QoS), Cable Diagnostics Function, fanless, loop prevention, DiffServ Code Point (DSCP) support, 1.5MB packet buffer, Storm Control, Link Aggregation
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 801.1p
Microsoft Windows Vista / XP / 7, Windows 8 / 8.1, Windows 10
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
55 W
Performance
4K entries
Jumbo Frame Support
15KB
4 x 1000Base-T RJ-45 PoE - 15.4 W , 4 x 1000Base-T RJ-45
External power adapter
FCC, RoHS
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
BYDZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
BYDZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
BYDZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
BYDZ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.40
Ports: 8
Managed: Yes
POE: PoE
Brand: TP LINK
Price Range Ex VAT: 50 - 100
