TP LINK 6 Metre Antenna Extension Cable N Male
Quicklinx: 8998WS00 Mfr#: TL-ANT24EC6N
What happens when your wireless signal is too weak to connect to an access point in another building and you want to better position your wireless antenna in a higher or wider place to get a better signal?
The antenna extension cable is the answer to your problems. There is no need to move your access point or wireless router, which may sometimes be immovable, from place to place.
TP-Link TL-ANT24EC6N - antenna extension cable - 6 m
Antenna extension cable
Length
6 m
Connector
N-Series connector - male
Connector (Second End)
N-Series connector - female
Network Cable Type
Impedance
50 Ohm
Length
6 m
Connector
-10 °C
60 °C
