The Pharos Sector Antenna is a 2 x 2 MIMO Sector Antenna that is ideal for outdoor use when attached to a Pharos Base Station. These antennas, which feature high-gain directional transmission patterns, are excellent for building long distance Point-to-Multipoint coverage.
- TP-Link TL-ANT5819MS - antenna
- Product Type
- Antenna
- 13.3 cm x 5.7 cm x 70 cm
- 3.5 kg
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, pole mount
- Compatibility
- 802.11 a/b/g/n
- Frequency Range
- 5 - 6 GHz
- Gain
- 19 dBi
- Directivity
- Directional
- Product Type
- Antenna
- 13.3 cm
- 5.7 cm
- 70 cm
- 3.5 kg
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 a/b/g/n
- Frequency Range
- 5 - 6 GHz
- Gain
- 19 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.8:1
- Horizontal Beamwidth
- 90°, 120°
- Vertical Beamwidth
- 90°, 120°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x RP-SMA
- Weatherproof, MIMO technology
