TP LINK 5GHz 19dBi 2x2 MIMO Sector Antenna
Quicklinx: BXP5WS00 Mfr#: TL-ANT5819MS
The Pharos Sector Antenna is a 2 x 2 MIMO Sector Antenna that is ideal for outdoor use when attached to a Pharos Base Station. These antennas, which feature high-gain directional transmission patterns, are excellent for building long distance Point-to-Multipoint coverage.
TP-Link TL-ANT5819MS - antenna
Antenna
13.3 cm x 5.7 cm x 70 cm
3.5 kg
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, pole mount
Compatibility
802.11 a/b/g/n
Frequency Range
5 - 6 GHz
Gain
19 dBi
Directivity
Directional
Antenna
13.3 cm
5.7 cm
70 cm
3.5 kg
Aerial
Intended For
Wi-Fi
Outdoor, pole mount
Compatibility
802.11 a/b/g/n
Frequency Range
5 - 6 GHz
Gain
19 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
1.8:1
Horizontal Beamwidth
90°, 120°
Vertical Beamwidth
90°, 120°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA
Weatherproof, MIMO technology
