TP LINK 5-Port Gigabit Desktop Switch with 4-Port PoE
Quicklinx: DX0TWS00 Mfr#: TL-SG1005P
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: PoE
More than 50 In Stock
£36.55 ex VAT
£43.86 inc VAT
TL-SG1005P is a 5 10/100/1000Mbps ports unmanaged switch that requires no configuration and provides 4 PoE (Power over Ethernet) ports. It can automatically detect and supply power with all IEEE 802.3af compliant powered devices. In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network to where there are no power lines or outlets, where you wish to fix devices.
  • Overload arrangement
    TL-SG1005P has the priority function which will help protect the system when the system power is overloaded.
  • Port priority function
    This function will help to ensure the normal operation of the system.
  • Easy to use
    TL-SG1005P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-Link's TL-SG1005P 5switch is an ideal choice for expanding your home or office network.
TP-Link TL-SG1005P - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE) + 1 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
56 W
Performance
Switching capacity: 10 Gbps
MAC Address Table Size
2K entries
Flow control, full duplex capability, power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x
9.98 cm x 9.8 cm x 2.5 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
56 W
Performance
2K entries
Status Indicators
Power, link/activity
1 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
External power adapter
FCC, RoHS
9.98 cm
9.8 cm
2.5 cm
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 5
Managed: No
POE: PoE
Brand: TP LINK
