TP LINK 450Mbps Wireless N Access Point
Quicklinx: BLYQWS00 Mfr#: TL-WA901ND V4
Type: Radio access point
Connectivity: Wireless
Speed: 450Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£23.07 ex VAT
£27.68 inc VAT
TP-LINK's wireless N access points TL-WA901ND are designed to establish or expand a scalable high-speed wireless N network to connect multiple Ethernet enabled devices such as game consoles, Digital Media Adapters, Printers, or Network Attached Storage devices to an existing wireless network. They provide incredibly high wireless performance - 15x the speed and 5x the range of wireless G, guarantying multiple users more freedom to enjoy a great wireless Internet experience in the home, office, cafe or even a hotel or airport.
  • Expanding the wireless network
    The APs support a host of different functions that makes your wireless networking experience more flexible than ever before. The access points use repeater mode to expand the coverage and signal strength for the current wireless environment with Wireless Distribution Service (WDS) technology by connecting multiple access points. TP-LINK's 11N products also feature universal repeater mode so that even APs and Routers without WDS can be compatible. Users can use this feature to build up a larger wireless network in spaces with broader coverage areas and more users such as cafes, offices, and hotels.
  • Power over Ethernet
    For applications that require users to put a network device (such as an AP) in a location where there is no electrical outlet available, passive power over Ethernet is the best solution available. A Bundled power injector can supply both electricity and data streams over a single RJ45 cable to the access point even up to 30 meters away, giving users more freedom when choosing where to locate their APs to get the greatest signal quality possible.
  • Quick secure setup
    QSS or Quick Security Setup is a handy feature on the TL-WA901ND that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless access point automatically establishes a WPA2 secure connection, instantly protecting your network. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
  • Multi-SSID with VLAN support
    The Multi-SSID function allows users to create a separate network that segments users that need priority access or different levels of security. Different SSIDs refer to different VLANs with different services to protect confidential files from those who should not have access.
TP-Link TL-WA901ND - V4 - radio access point
Radio access point
External
Frequency Band
2.4 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
19.482 cm x 12.993 cm x 3.62 cm
Radio access point
19.482 cm
12.993 cm
3.62 cm
External
Wireless
Data Transfer Rate
450 Mbps
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP
Frequency Band
2.4 GHz
Max Range Indoors
30 m
Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, DHCP server, Multiple SSID support, SNMP support
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Aerial
Antenna
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
4 dBi
1 x 100Base-TX - RJ-45
PoE injector
1 x network cable
FCC, RoHS
PoE
External power adapter
5.8 Watt
10 - 90% (non-condensing)
BLYQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
Speed: 450Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: TP LINK
Price Range Ex VAT: 0 - 50
