Product
TP LINK 4-Port SafeStream Gigabit Broadband VPN Router
Quicklinx: 897YWS00 Mfr#: TL-R600VPN
Type: Router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet
Speed: [N/A]
Rackmount or External: External
£54.29 ex VAT
£65.14 inc VAT
TL-R600VPN, TP-LINK's SafeStream Gigabit Broadband VPN Router, supports Gigabit Ethernet connections on both WAN and LAN ports which guarantee high-speed wired connectivity. What's more, it integrates multiple VPN protocols, high-security and high-performance VPN capabilities, which enable employees' remote connections to their main offices as secure as if they were in the main office. Besides, TL-R600VPN's abundant security strategies such as SPI Firewall, Dos Defense and IP-MAC Binding help protect your network against most known attacks. TL-R600VPN is an ideal partner for small offices, which need cost-effective and reliable VPN solutions.
  • High-security VPN capabilities
    TL-R600VPN supports IPsec and PPTP VPN protocols and can handle IPsec/PPTP/L2TP pass-through traffic as well. It also features a built-in hardware-based VPN engine allowing the router to support and manage up to 20 LAN-to-LAN IPsec and 16 PPTP VPN connections. Advanced VPN features include: DES/3DES/AES128/AES192/AES256 encryption, MD5/SHA1 authentication, Manual/IKE key management, and Main/Aggressive negotiation modes.
  • Abundant security features
    For defense against external threats, TL-R600VPN features SPI Firewall function. Additionally, it can automatically detect and block Denial of service (Dos) attacks such as TCP/UDP/ICMP Flooding, Ping of Death and other related threats. Moreover, this router provides IP/MAC/Domain name filtering functions, which forcefully prevent attacks from intruders and viruses. For applications such as FTP, TFTP, H.323 and RTSP which are not well compatible with NAT, TL-R600VPN offers administrators one-click enable of ALG choices corresponding to the above four mentioned applications.
  • Safety minded enterprise investments
    Professional lightning protection technology is designed to prevent electrical surges from penetrating the interior of the electrical equipment and is discharged harmlessly into the Earth. This router is designed to prevent lightning up to 4KV in well-grounded connection conditions. This feature ensures that networking infrastructure investments remain as safe as possible from one of mother nature's more violent situations.
TP-Link SafeStream TL-R600VPN - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
VPN throughput: 20 Mbps , NAT throughput: 120 Mbps
IPSec VPN tunnels: 20 , PPTP VPN tunnels: 16 , Concurrent sessions: 10000
Network / Transport Protocol
TCP/IP, PPTP, L2TP, ICMP/IP, IPSec, PPPoE, FTP, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP, TFTP
VoIP Protocols
H.323
DMZ port, NAT support, VPN support, ARP support, Syslog support, DoS attack prevention, MAC address filtering, VPN passthrough, IP address filtering, firmware upgradable, SNTP support, Access Control List (ACL) support, virtual server support, DHCP server, bandwidth control, port triggering, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, UPnP
20.9 cm x 12.6 cm x 2.6 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Static IP routing
HTTP, TFTP
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, UPnP, FCC, RoHS
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
Status Indicators
Power, system, WAN, LAN
IP Telephony
VoIP Protocols
H.323
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
20.9 cm
12.6 cm
2.6 cm
10 - 90% (non-condensing)
897Y C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
897Y C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
897Y C2G 2m Cat6a Shielded Patch - Blue In Stock £7.15
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Speed: [N/A]
Brand: TP LINK
Price Range Ex VAT: 50 - 100
