TP LINK 300Mbps Wireless N Nano Router
Quicklinx: BJ7GWS00 Mfr#: TL-WR802N
  • IEEE 802.11n
More than 50 in stock
£18.82 ex VAT
£22.58 inc VAT
The TL-WR802N is designed for use with tablets, smart phones, handheld game consoles and other portable electronic wireless devices. The devices, which can be powered by an external power adapter or USB connection to a computer, can conveniently connect to the Internet and share the connection around an average sized room at 300Mbps. The device's tiny size makes it ideal for use on the road and is powerful enough to satisfy almost any basic wireless application requirement.
The TL-WR802N is the perfect travel companion for anyone who needs fast, easy Internet access on the go. Portable and compact design easily fits into a pocket or the palm of your hand. Simply plug a hotel room's Ethernet cable into the port provided and enter a default password to instantly create a wireless hotspot in the room. It can be powered by an external power adapter or via a USB connection to a computer. When traveling, users can plug the TL-WR802N into computer's USB port and share Wi-Fi connection with family and friends.
  • What is the TL-WR802N
  • Portable and compact - ideal for home and travel use
  • Flexible power supply - easy to take on the road
    TL-WR802N can be powered by an external power adapter or via a USB connection to a computer. When traveling, users can plug the TL-WR802N into computer's USB port and share Wi-Fi connection with family and friends.
  • Multiple operation modes
    TL-WR802N supports Router (default), Repeater, Client, AP and WISP modes to enable various wireless applications to give users a more dynamic and comprehensive wireless networking experience.
TP-Link TL-WR802N - wireless router - 802.11b/g/n - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Firewall protection, routing, repeating mode, Stateful Packet Inspection (SPI), DoS attack prevention, manageable, Access Point operational mode, WISP mode, Wi-Fi Multimedia (WMM) support, wireless bridge mode, reset button, Wireless Client Mode, IP-MAC binding
5.7 cm x 5.7 cm x 1.8 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8, Windows 8.1, Microsoft Windows 98SE/2000/NT/XP/Vista/7
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPTP, L2TP, IPSec
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
External power adapter
1 x USB cable , 1 x network cable
5.7 cm
5.7 cm
1.8 cm
10 - 90% (non-condensing)
BJ7G C2G 2m USB 2.0 A/B Cable - Black In Stock £3.63
BJ7G C2G 5m USB 2.0 A/B Cable - Black In Stock £5.26
BJ7G C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.83
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 300Mbps
Brand: TP LINK
Price Range Ex VAT: 0 - 50
