TP LINK 300Mbps Wireless ADSL2+ Modem Router
SECURELY ACCESS YOUR HOME NETWORK FROM ANYWHERE!
Quicklinx: 77S0WS00 Mfr#: TD-W8960N
  • IEEE 802.11n
The TP-LINK Wireless N ADSL2+ Modem Router (TD-W8960N) is an all-in-one device that combines the functions of a high speed DSL modem, a 4-port 10/100Mbps NAT router and a wireless N access point. The TD-W8960N is designed to give you a one-stop solution to acquiring and sharing high speed Internet access over a wired/wireless network.
Supporting the latest ADSL standards to provide higher performance and longer reach from your Internet Service Provider (ISP) Digital Subscriber Line Access Multiplexer (DSLAM), the TD-W8960N brings with it much higher speed than a dial-up connection without tying up the phone line.
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 15x the speed and 5x the range of conventional 11g products. Now you can share your high-speed DSL Internet connection, photos, music, videos, printers, Network Attached Storage (NAS) and even the bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard! The TD-W8960N supports QoS to enable smooth VoIP/IPTV streaming and lag-free online gaming.
Featuring IPSec VPN function, TD-W8960N allows off-site or traveling users to securely access the company's central network through the Internet. VPN is short for Virtual Private Network, which creats encrypted tunnels through the Internet between the company's private network and the remote or traveling users off-site. These tunnels are using virtual connections instead of the dedicated, real-world connection such as leased line. Featuring IPSec VPN function, the TP-LINK TD-W8960N is no longer just a wireless ADSL modem router, it can work as a VPN gateway, which supports up to 10 IPSec VPN tunnels simultaneously. As such, users can allow for complete data privacy for the access and exchange of user's most sensitive data from home to corporate network or between remote branch offices safely.
  • 3-in-1 device
  • Access high-speed Internet
  • Sharing Internet through wireless
  • Quick Secure Setup (QSS)
    QSS or Quick Security Setup (QSS) is a handy feature that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless router or entering the PIN Code in the net card, it automatically establishes a WPA2 secure connection, instantly protecting your network. With just one click of the QSS button, it automatically establishes a WPA2 secure connection for solid security in under a minute.
  • Keep data secure
TP-Link TD-W8960N - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Permanent virtual circuits (PVC): up to 8 , IPSec VPN tunnels: up to 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS, DDNS
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP
Firewall protection, DMZ port, NAT support, VLAN support, IGMP snooping, traffic shaping, packet filtering, MAC address filtering, VPN passthrough, URL filtering, parental control, IP address filtering, firmware upgradable, MIMO technology, IPSec VPN, ACL support, QoS, virtual server support, WPS, IPSec passthrough, port forwarding, bandwidth control, SPIF, DNS relay, application filtering, DoS, SYN Flooding, Ping of Death
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
18.16 cm x 12.57 cm x 3.62 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000 / NT, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
Max Transfer Rate
24 Mbps
WAN: 1 x ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 3 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
ADSL splitter
1 x phone cable , 1 x network cable
Software Included
Easy Setup Assistant
18.16 cm
12.57 cm
3.62 cm
10 - 90% (non-condensing)
77S0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
