TP LINK 300Mbps Universal Wireless N Range Extender
Quicklinx: 8GC4WS00 Mfr#: TL-WA850RE
Type: Wi-Fi range extender
Connectivity: Wired, Wireless
Speed: 300Mbps
Protocol: IEEE 802.11g, IEEE 802.11n, Fast Ethernet, IEEE 802.11b + 1 more
Compatibility: Mac, PC
  • IEEE 802.11n
Hurry, only 3 left in stock!
£14.87 ex VAT
£17.84 inc VAT
TP-LINK's TL-WA850RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones". With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier. What's more, its Ethernet port allows the TL-WA850RE to act as a wireless adapter to turn a wired device into a wireless one.
The TL-WA850RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA850RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA850RE or vice versa. An additional push of the pair button can quickly establish an encrypted connection with client devices.
The TL-WA850RE's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
5 signal lights represent the current signal strength that TL-WA850RE receives from existing router, which can help to find the right location to place the range extender so that the TL-WA850RE can achieve the best possible range and performance of the network.
Works seamlessly with all 802.11 b/g/n wireless devices. It is also compatible with the latest Windows 8 operating system.
  • 300 Mbps Range Extender
    The TL-WA850RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300 Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
  • Flexible deployment
  • Plug and Play
    With no wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA850RE or vice versa. An additional push of the pair button can quickly establish an encrypted connection with client devices.
  • Ethernet bridge
    The TL-WA850RE's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
  • Smart signal indicator light
TP-Link TL-WA850RE 300Mbps Universal Wireless N Range Extender - Wi-Fi range extender - Wi-Fi
External
United Kingdom
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
UNIX, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8
11 cm x 6.58 cm x 7.52 cm
3-year warranty
11 cm
6.58 cm
7.52 cm
United Kingdom
External
Wireless, wired
Cable(s) / Media Type Supported
Network cable
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Spread Spectrum Method
DSSS
Network / Transport Protocol
TCP/IP
Frequency Band
2.4 GHz
Status Indicators
Power, LAN, wireless, WPS
Auto-negotiation, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna Qty
2
1 x 100Base-TX - RJ-45
1 x network cable
Plug and Play, RoHS
3 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
10 - 90% (non-condensing)
8GC4 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
Connectivity: Wired
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11n
Protocol: Fast Ethernet
Protocol: IEEE 802.11b
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
Antennas: 2
Brand: TP LINK
