Product
Brand
TP LINK 3 Metre Antenna Extension Cable R-SMA
Quicklinx: 8992WS00 Mfr#: TL-ANT24EC3S
What happens when your wireless signal is too weak to connect to an access point in another building and you want to better position your wireless antenna in a higher or wider place to get a better signal?
The antenna extension cable is the answer to your problems. There is no need to move your access point or wireless router, which may sometimes be immovable, from place to place.
TP-Link TL-ANT24EC3S - antenna extension cable - 3 m
Antenna extension cable
Length
3 m
Connector
RP-SMA - male
Connector (Second End)
RP-SMA - female
Network Cable Type
Impedance
50 Ohm
Length
3 m
Connector
RP-SMA - male
RP-SMA - female
-10 °C
60 °C
