Product
TP LINK 24-Port 10/100Mbps Desktop Switch
Quicklinx: BLZ1WS00 Mfr#: TL-SF1024M
The TL-SF1024M Fast Ethernet Switch is designed for SOHO (Small Office/Home Office) or workgroup users. All 24 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SF1024M can save the power consumption, making it an eco-friendly solution for your business network.
  • TP-LINK green technology
    TL-SF1024M Fast Ethernet Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials.
  • High performance
    TL-SF1024M Fast Ethernet Switch provides 24 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports. Featuring non-blocking switching architecture, TL-SF1024M forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1024M work reliably.
  • Easy to use
    The auto features of this switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100 Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SF1024M - switch - 24 ports
Switch - 24 ports
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
Switching capacity: 4.8 Gbps
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, Green Ethernet, fanless, Back Pressure Support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
22.2 cm x 12.6 cm x 4.5 cm
Switch - 24 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
8K entries
Status Indicators
Power, link/activity
24 x 100Base-TX RJ-45
External power adapter
3.68 Watt
FCC, RoHS
22.2 cm
12.6 cm
4.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
BLZ1 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
BLZ1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
BLZ1 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
BLZ1 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.36
