TP-LINK smart switch TL-SL2428 is equipped with 24 10/100 Mbps RJ45 ports, 4 10/100/1000 Mbps RJ45 ports and 2 combo Gigabit SFP slots. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Smart Switch TL-SL2428 is a cost-effÂective product solution for the small and medium business. TL-SL2428 has useful security features. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and Gigabit capability, TP-LINK smart switch TL-SL2428 provides you the ideal access-edge solution.
Advanced QoS features
To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including port priority, 802.1P priority and DSCP priority, to ensure that voice and video are always clear, smooth and jitter free. -
Abundant layer 2 features
For more application of layer 2 switches, TL-SL2428 supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, Port Isolation, Port Mirroring, STP/RSTP/MSTP, link aggregation group and 802.3x flow control function. Any more, the switches provide advanced features for network maintenance such as loop back detection, cable diagnostics and IGMP Snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access. -
Enterprise level management features
TL-SL2428 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
- TP-Link JetStream TL-SL2428 - switch - rack-mountable
- Switch
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100 + 4 x 10/100/1000 + 2 x combo Gigabit SFP
- Performance
- Bandwidth: 12.8 Gbps , Forwarding performance: 9.5 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
- Flow control, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support, Dynamic ARP Inspection (DAI), LACP support, Link Aggregation Control Protocol (LACP), IP-MAC binding
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 18 cm x 4.4 cm
- Switch
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 8K entries
- Encryption Algorithm
- TLS 1.0, SSL 3.0, SSL 2.0
- Authentication Method
- Secure Shell (SSH), RADIUS
- Status Indicators
- Power, system, link/activity
- 24 x 100Base-TX RJ-45 , 4 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- FCC
- 44 cm
- 18 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
